peter_n
I'd go with Roland's recommendation of centering the lens over the ballhead, I use a similar rig to his, with the exception that I've replaced the center column with a Markins base plate for extra rigidity. I also recommend the ClearSight camera plate if you invest in an Arca Swiss type of quick release system (expensive but increasingly useful as you acquire kit!). The grip with the center tripod hole is a good short-term solution as the grip will help on the tripod as well as off it.
It is good to think ahead when buying a tripod, so I'll go a bit against the trend here. When I put together my kit all I had was an M6 and the tripod rig I got was definitely overkill for that. Now my biggest camera is a pretty heavy 617 film panoramic and my original rig handles it with ease. Since you are keen on landscapes a larger format of some kind could well be in your future. When you take a look at whatever piece of kit you fancy make sure you won't have to sell it in a year or two because it can't handle something a bit bigger/heavier.
Tough to say when you have a budget, but quality always lasts longer (and has a lower cost of ownership) than inexpensive. There is a reason Gitzo tripods are considered the best. I bought a used G-1228 from a dealer here in Boston for ½ the new price, it had been well used and looked absolutely terrible. But I dismantled it, cleaned, lubed, replaced all the section sleeves, and put it back together, and it still looked terrible. But it worked like new, and it still does. They are incredible, you get one of these tripods and you never have to buy another.
So it's a bit soggy in England? You should try the north-east US! We've had about 5 weeks of continuous rain here, June was the worst month for rain since records began in 1903. We had 4 inches in eastern Massachusetts one morning last week! The Boston Globe newspaper had plans for you to build your own ark. Last 3 days it hasn't rained so maybe we won't need to do it. That RedSnapper tripod, do those rubber feet unscrew to reveal spikes? Very useful in mucky weather...
