Underexposure Issue with Pan F+
David R Munson
写真のオタク
11:34 AM
Chicago, IL
I've been shooting a fair amount of Pan F+ and the results have generally been excellent. However, I've shot a handful of rolls with a #29 deep red filter and despite generous exposure compensation I come out with negatives so thin as to be totally useless. I've tried some crazy exposure compensation, making sure my developer isn't bad, etc. The only thing I can think of is that I'm venturing into the territory where this film's red sensitivity starts to drop off. Has anyone here ever run into this problem? Does a spectral sensitivity issue seem like the culprit? It's the only thing I can think of at this point because I've gone over every other factor and ruled it out.
EDIT: Forgot some specifics. I usually shoot it at EI 32, which gives me an EI of 2 with a #29 red filter. Development has been in both HC-110 and D-76. Mostly shot with a Mamiya 645 Pro with an 80mm f/1.9 wide open. Incident metering.
I've been making exposure corrections in that range, but to no avail. Same filter with other films with similar corrections (4+ stops) gets me fine results.
I thought of that, but none of my exposures were that long. Most of the work was in full sun shooting wide open. At EI 32 that's 1/2000 sec at f/1.9 without filter correction. With filter correction that puts me around 1/250 or 1/125 for most exposure.
I did dig up a sensitivity graph for Pan F+ and it does look like sensitivity begins to drop off severely just after the point where a #29 would start transmitting.
Your math is wrong. 1/250 is only 3 stops, 1/125 only 4 stops.
It's likely not too late to do some intensification on those negs. I've used selenium toner in the past on images that didn't print well on a grade five paper. After adjusting dilution and times on a couple of snip tests, the rest printed outstandingly at grade three.
I'm still a fan of that poisonous stuff.
The point remains, though. IRL I gave it plenty of exposure.
I'm all for trying it, but it'll have to wait a while. I'm moving to another continent.
