Voigtlander Ultron 35mm F2 Aspherical Images
Hi all! I just got the lens! Out of curiosity, have you guys experienced seeing the same amount of grease showing on your lens as I have? In looks rather much as it oozes out like this. To be honest, this is the first new lens I've purchased so would appreciate your feedback.
https://imgur.com/a/TpKYodM
Mine was similar. They went a bit overboard with the grease at the factory. I just carefully wiped off the excess with a cotton bud (Q-tip?). It’s not doing anything useful on the inside of the mount so you may as well wipe it off.
Voigtlander 35mm f2 Ultron VM lens, Sony A7II
Yokohama, Japan - February 2019
Mike
My sample is coming the next days! Will post samples from an A7 and analog M. I can compare it to the summarit 2.5 and the Cron V4.
It should look quite familiar to many ZM lens owners...
Am I the only one who would like to have a way to limit focus range to 0.7m? My M3 (that couldn't be modified to focus down to 0.7m) drove me mad with loosing rf coupling with "modern" lenses.
I understand that Cosina wants to sell those lenses to folks that use them with adapters on other mirrorless cameras, but a screw to limit the travel beyond 0.7m (heck, even 0.9m when they are at it) shouldn't be that hard to do, right?
Totally agree, I kept the ZM 35 f2 over VM Ultron 35 1.7 because of this, although I do believe that optically the VM Ultron is slightly better than the f2 Biogon
