Vuescan - Printed Size setting
Captain Kidd
9:21 AM
Hello,
In vuescan in the 'Output' tab there is an option to set the 'Printed Size'.
Relating to negatives, is it best to set this to 'Scan size', set a high dpi and then resize yourself in photoshop? or set the 'Scan size' to the size you intend to print, for instance 12 x 8 and then set the dpi to something suitable.
Would I be right to say by picking a larger 'Print size' than the actual negative your inviting vuescan to do the resampling, is there any danger in that?
Thanks
https://www.hamrick.com/vuescan/html/vuesc33.htm#outputprintedsize
Apparently it does not resample. So it just changes the internal DPI setting of the file to give you the inputted print size. A pretty useless thing generally, in my opinion.
Personally I think you should scan at an appropriate DPI for maximum resolution and then resize in PS to your target print DPI and save to a different file.
Set it to Scan Size and scan at the highest DPI your scanner gives. If you scan at a lower resolution, then you may decide later you want to make a larger print, and need to rescan the film and redo all the editing you did to it before. Easier to scan large the first time.
