Vulcanite Replacement Problem
That was much more work than I anticipated, but the result is great:
Now on to my other M4, which will be covered in "tan" 😀
Simply Gorgeous 🙂🙂🙂
The nice thing is that once you remove the old vulcanite, it is really easy to change out the new covering in the future if the whim strikes you.
Tip: put some Purell hand sanitizer (without moisturizer!) on the sticky side of the new cover. This will allow you to make adjustments for around 20 min until it evaporates and the glue bonds.
Do not use this with light coloured leathers! Only with blacks, dark blues etc.
On my medium blue M3 the purell (I used the actual Purell brand) stained the leather permanently. So in places the blue is darker.🙁
This may only apply to using real leather like the stuff from cameraleather.com, not synthetics
On my medium blue M3 the Purell (I used the actual Purell brand) stained the leather permanently. So in places the blue is darker.🙁
This may only apply to using real leather like the stuff from Cameraleather.com, not synthetics
If you do it really, really carefully, you could end up with an entirely individual 'camouflage' pattern. 😀
The best way I've found is to use a hair dryer and a flat blade. If it doesn't come off in one piece then it's not hot enough. Use a small drier with a thin nozzle to direct the heat away from windows etc. Any residual glue is easily removed by using q-tips soaked in acetone/nail polish remover to saturate the glue. It then wipes off easily.
The way to do it is to remove the shell from the body completely and to remove all the details mounted to it, such as the bayonet release button and the selftimer etc. Then you can place the shell in an oven or (better) in hot water. When hot the vulcanite is taken off easily.
Erik.
I've done this some two or three times, and always using the strip remover from a hardware store. It was so strong the last time it stripped the paint off the screws, but then leaving it overnight made the vulcanite removal a cinch. However, maybe the next time I'll try the heat method instead.
