Aaaaaand ... 6 hours later ... the negatives are developed AND silver printed     Am doing side by side comparisons (of 2x3 stuff) of the same woodland scene with the variables being more-or-less Tri-X, HP5+, and PL100M using D-76 1+3.  The first two were also compared using D-23 1+9+0.5g/l NaOH.  Both developers employed for 25 min Semistand development.
Waiting for the prints to dry to make any final judgment but looking at contrast and sharpness particularly across these various combinations
I put this up on Photrio as well and thought I'd share here as well ...
There is a dead fallen tree in a forest preserve near where I live that just lights up with high angle light in the mid-morning to early afternoon.  Not only do the dead branches have a lot of detail, so too does the forest behind it.
I tripod mounted a "Baby" Speed Graphic with a 180mm f/5.5 Tele-Arton lens there on two different days.
The first day. I shot old (11/1969) Tri-X and and (2018) HP5+ sheet film the first day.  Which was semistand processed for 25 min in D-23 1+9 with 0.5g/l NaOH added to it.
The second day, I took the same two films with me but added Efke PL100M, all of which were semistand processed for 25 min in D-76 1+3.
Although taken on  different days,  the lighting conditions were essentially the same with bright high sun and clear blue cloudless sky above.
I wanted to see how much difference the developers and films made as regards to sharpness and grain, noting that I was working with out of date/unavailable films in these tests.  (I happen to have a fairly large stash of out of date HP5+, PL100M, and Tri-X in 2x3 in my freezer.)
I made 8x10 silver prints from these negatives and roughly matched them for exposure and contrast.
Preliminary findings, subject to revision as I inspect more carefully:
- All things being equal, HP5+ is somewhat less contrasty in this controlled experiment than Tri-X.  However, it is possible to get nearly identical print results from the two negatives using split-VC printing and exposure management under the enlarger.
- The Efke PL100M produced a somewhat thinner negative than the Tri-X and HP5+ did in D-76 semistand development.  However, the negative was properly exposed and - again - split VC printing and  enlarger exposure management brought the resulting print in line with the other.  It's not shocking this negative was different since the emulsion is rated at 1/2 the daylight speed of the other two films. Probably some tuning  of the development time might be in order. I care about this, because even though Efke is long out of business, I have tons fo this film in 2x3 in my freezer. Moroever, Adox CHS100II may be a close replacement, so what I figure out or the Efke should translate, at least to get going.
- I would have expected the ultra-dilute D-23 with lye to produce much sharper outcomes than the D-76 1+3.  It did not. The observed sharpness of the final prints is almost indistinguishable between the two developers.
- Even though this is very old Tri-X out out date as of 11/1969 (Kodak has not made 2x3 sheet film in ages), it seems visibly slightly sharper with less "crunchiness" than HP5+.  This is consistent with my less rigorous testing of the films with more recent 35mm emulsions.
- The prints are still just a tad damp and I need to go look in detail, but the Efke looks like it may have been the sharpest of the lot.  This is consistent with my prior use of this film is which has very high acutance out of the box.
- I did not notice any objectionable grain, but I wouldn't expect to at 8x10.
- At some point, I'd like to drill into this a bit more and compare, say, Tri-X and Efke against these findings but using HC-110 1:128 and Pyrocat-HDC 1.5:1:200, again using semistand development.
