faris
would give you the same dof on an M8 as on a M7?
What and how are they related?
Thanks.
Thanks.
Thanks.
DOF does not change if you use with M7 or M8 AS LONG AS you shoot from the same distance.
It changes IF you try to frame your object in the same way. Since the film/sensor size is different, to frame your object in the same way,
1) you have to use shorter lens with M8 if you keep the distance the same,
or
2) you have to come closer with M7 when using the same lens.
If you do either 1 or 2, then DOF will be different for M7 and M8.
Hiromu
Anyway, Leica claims in all manuals that the DOF is the same. I suppose they know a thing or two about optics.🙄
No doubt, so please explain above. I'd be interested to know where I, or Cambridge tutorial, got this wrong....seriously.
Jef
If I remember correctly from the aforementioned other forum. Online DOF calculators such as the one you refer to use a smaller circle of confusion in the digital lens calculations than in the film calculations. Notice that each crop size also returns different numbers. They do that because of the difference in the image size with film versus a digital non full frame sensors. This is done to compensate for the apparent change in DOF when the images are viewed at the same enlargement. The lens formula does not change when they are designing a full frame lens for film or digital. What does change is some of the compromises in the design. Digital lens must suppress the sensor reflection of itself. The mirror in the mirror in the mirror on and on. Film does not reflect upon the rear lens elements to the degree that a digital sensor does. 😕
You'd have to ask Leica for an explanation of their statement. I am not their spokesman.No doubt, so please explain above. I'd be interested to know where I, or Cambridge tutorial, got this wrong....seriously.
Jef
Not quite. There is one more factor. As film has a thickness the image points are three dimensional within a semi-opaque medium (film emulsion) that give less defined COC-s and COC-s that are deformed elipsoid towards the cornenrs. Thus the sensor will give a steeper DOF gradient, giving the impression of a more narrow DOF.jaapy is correct, the DOF is a function of lens aperture, focal length of lens and the focus distance, not the image size on the "receptor", be it film or sensor. However, hiromu is also correct, to a point, we see differently through a non full frame digital viewfinder than we do through a full frame film view finder. If you doubt me, then take any DSLR and a compatible film slr, with each stand in one spot and view a nearby object, first with the DSLR and then the film SLR both cameras using the exact same lens at the same aperture and the same focus distance. You will see a different framing of the object. In this example, the DOF would be exactly the same as it was the same lens at the same aperture and the same focus distance! However, if we were to move closer with the film SLR or farther away with the Dslr in order to achieve the same framing through the viewfinder as viewed with the other camera, we would have changed one of the variables in determining the DOF; therefore the equation must remain true so the DOF will have changed, albeit slightly.
This issue was argued extensively on another forum dedicated to one lens mount compatible with the brand's film SLRs and DSLRs. It is hard to understand, but easy to demonstrate if you perform my little experiment. DOF is a physical function of the mathematics of the lens design, not the recording method. 😉
