I agree with Doug's very complete mini-review of the Heliar 50mm 2.0 and also with David's contribution of the Avenon 28mm 3.5. I own them both and dearly love them.
Also, the before mentioned Elmar 50mm 3.5 is a true gem. I own an uncoated nickel one and a chrome one with an even earlier serial number that was factory upgraded to a modern chrome and coated lens. Again, I can concur.
Two more lenses I'd like to add though.
First is a very early Jupiter-9 labelled 85mm 2.0 lens with Carl Zeiss Sonnar optical block. It has a minimum focusing distance of 1.8 meters and the index marks for distance and aperture do not line up, signalling that the lens is made from non-Russian parts. This is the second one I own and I'm constantly impressed by sharpness and rendering.
They are harder to find but aren't spotted by either collectors or sellers so can be had for reasonable prices if you invest time.
The second lens is a bit of a rangefinder equivalent of the now much appreciated Trioplan lenses, it's the early Topcor 50mm 2.0 LTM, the non-S model. It does swirly bokeh wide open, and is pretty sharp with still softer corners when stopped down. Once at 8.0 it's sharp overall.
These are the full-chrome early lenses, fully made from brass (around 225 grammes heavy) and have whiskey colored coating with a tinge of pink. They are probably single coated.
Several of the above mentioned lenses are
featured in this article on my web site.
