Zeiss Ikon Contax IIa/IIIa CLA notes
Just signed up here because I ran across this thread *after* doing full services to two IIa's and wish I had this info prior. I found out through trial and error the very counter intuitive fact that decreasing tension actually increases effective top speeds. Do you understand how? Because I certainly don't. It would be very helpful to understanding these weird designs.
Also, did Henry clarify why a modern tester would read the 1250 speed wrong? As far as I can tell, these do in fact work like normal modern shutters, in that they have a fixed high speed travel time and use variable slit width to make different effective speeds. Is that not actually correct? The full gate can't possibly be open for only 1/1250, the curtain speeds are way too slow. I was able to fix 1250 traveling closed by simply delaying second curtain open (i.e. enlarging the slit width) via the first curtain cam. Once that was done, that led down the rabbit hole of finding proper tension and finding that the camera's (very high) current tension setting was only yielding 1/300 at 1250 - something I noticed Henry mentions being a common problem with previously serviced cameras sent to him. What I can't understand is *why* significantly less tension actually sped it back up to 1/1000 on my tester - all while having no meaningfully negative impact on medium and low speeds.
Sorry for the very slow reply! In all of my emails to Henry he always said there was no slit and the shutter works as a blade. As far as clarification on shutter speed testers he said that most shutter testers are designed around Leica type shutters thus leading a good 1/1250 to read more like 1/800.
Hi everyone! This is an amazing thread, thanks a lot to all of you that contributed with information, sources, etc., it has really helped me understand how the shutter mechanism works in these cameras.
I'm currently working on my IIa and would like to lubricate the gears before reassembling it, does anybody have any advice on where/what to lubricate?
I don't want to overdo it, so I thought I'd ask before I start oiling everything...
Hi folks, after cleaning, lub and re tensioning my iia kind really working good. But after +- 50 test shots, the shutter stuck. No winding and no button action. Disassembled again a noted the shutter button kept pressed. I dont know what could be. I tried to force fire via press lever but nothing
Did you ever get your IIa fixed? I have the same problem with a broken cord. I used 30lb fabric fishing line but I wasn't sure in what position to have the shutter blades in when I slid it back to the camera top. Mine will not wind the curtains.
I did not and gave up on the camera.... It became a parts body.
