largedrink
Down Under
Another great source of information about Zeiss is the complete set of Zeiss Historica issues on Mike Eckman's website:
https://mikeeckman.com/zeiss-historica/
I found some more CLA information in Camera Maintenance & Repair Book 2 by Thomas Tomosy, Amherst Media 1997.
Yes, but this is for the Contax II and III. This thread is about the Contax IIa and IIIa, which have an entirely different shutter with nothing in common. Even the operational principle is different.
Can I take us back to getting the higher shuttter speeds of a IIa/IIIa to work? As mentioned on the main Contax thread, I have recently picked up a colour-dial IIa that was in almost as-new cosmetic condition but had a non-functioning rangefinder and shutter that ran it only one speed. Doing a minimum strip-down and just carefully cleaning and lubricating the shutter components under the top plate, and lubricating the rangefinder prism pivot proved a 90% fix, as I had hoped it would. However, at 1/1250th the shutter travels closed and it does the same randomly at 1/500th. I am not sure this is simply a case of the inaccessible bearings needing to be lubricated - obviously something to try and eliminate as the problem - or it being a better (or even good) idea to loosen the ring nut and adjust the disc on top of the first curtain to delay release of the second. Has anyone tried this/have a cautionary tale of why you shouldn't?
I found the problem: the high speed lever did not engage in the high speed couples one the 2nd cam shaft. Understanding the mechanisms helps... all information was already there 😀Hello,
at first a big thanks to everyone who contributed to this amazing collection of knowledge! I am currently working on a IIIa, where the slow and medium speeds seen to work fine, but at high speeds and on B, T the curtains are running down without separating. The camera is open and and looks like in a quite good condition. Does anybody have some ideas?
I don't know about any source. I think this is a silk cord, but I would probably try to replace it with a Kevlar nano cord like paracord has one. May compare the diameter first. I don't know if this works and how the stiffness compares to the original one, but what are the options...Does anyone have a source for this shutter cord?
Hi everyone new member here. Just thought I'd add to this resource with information I've received from Henry Scherer of ZeissCamera.com.
On the tension of the shutter curtains, several things should be noted. Firstly tensioning the curtain will decrease the top 3 speeds therefore having a lower curtain speed is ideal. The method for which Henry told me was to tension the shutter just enough that it does not hang loose and then completely assemble the camera. after assembly, the shutter can be tensioned until there is no blanking at 1/1250.
Something else to be noted is the spring mechanism in the curtain assembly works as basically an analog computer that is working out the way the two curtains share force, this process takes time. It may be the day after your tensioning the 1/1250 may blank again therefore it is necessary to tension until the 1/1250 stops blanking again. Henry has said that he has had some cameras which will keep changing even 6 months later.
Another point made to me was that due to Leica's patents, Contax had a very hard time designing around the Leica-type shutter, this led to the creation of the vertical slat shutter observed in Contax cameras. The shutter functions differently from a Leica-type shutter as instead of passing the slit of light over the film plane the whole curtain assembly remains open the whole time of the exposure with the second curtain coming down like a blade to end the exposure. This design means many shutter testers can not read the speeds correctly. A good 1/1250 may actually come up as around 1/800 on a modern shutter tester
Oleg at OKvintagecameras. Radu at 3R Camera. Mark Hansen at ZeissIkonRolleiRepair.Given Henry Scherer's unfortunate situation and departure from the business of servicing cameras, is there anyone else working on Contax RFs professionally and competently, anywhere, for any price?
Thanks very much. Mark Hansen has done my rolleiflex before, so I'll give him a call. I really just need the rangefinder adjusted but I'm afraid to take it apart. 🙂Oleg at OKvintagecameras. Radu at 3R Camera. Mark Hansen at ZeissIkonRolleiRepair.
