kshapero
South Florida Man
Anybody can offer a comparison between the ZI vs RD-1(s) Viewfinders of each?
Love my ZI, might like to pick up a RD-1 if the VF is comparable.
Are you saying that the RD-1 is not useful with a 28mm or 35mm lens? if so why?Timmy P said:I've never used a ZI, but I know that the RD-1 viewfinder is almost exactly the same as the one in a Bessa R3A, if that helps at all.
Oh, and The RD1 is a very different beast from film rangefinders. If you like wide angles, as in anything under 40mm, I'd stay away from the Epson. I like 50mms myself, so I am currently swimming.
Good luck with your choice,
-Tim
using my ZI at night is a OK. Using a DSLR at night, at best difficult. How about the RD-1?wintoid said:I have both. It's not night and day, but the Ikon VF is definitely a bit better.
kshapero said:Are you saying that the RD-1 is not useful with a 28mm or 35mm lens? if so why?
georgef said:I haven't used the Z1, but have the RD1. It has by far the brightest digital camera viewfinder (I also have not used the M8).
I also use it with the CV 15mm for the equivalent of a 21mm lens with an external viewfinder. Truth is, I only put the ext VF on because I like the look, as I have gotten used to the approximate FOV of the lens through the regular viewfinder.
I also used it with the CV 21mm and have the CV 28 1.9 almost always on it, so I will disagree with Tims statement about sub-40mm lenses.
