ferider
Here is how you can check you equipment:
1.) at night, check the camera's infinity focus using a star or the moon.
2.) close focus check: put the camera on a tripod, put the lens on a given mark (like 1m or 4 ft or so), and put the tripod the same distance away from a given object (measured with a tape measure). See if the object is in focus in your RF. You can also do test photos like this:
using some test target, like a printed pattern, or a measurement tape.
3.) Next, your Hassi photos are good. Try to emulate them using your Leica, i.e. using the same film, same post-process/scanner and similar photographic conditions.
Then, come to our next Beer and Gear (date not set yet, but should be in a couple of weeks or so), and you'll find people who can help you if there are problems.
Roland.
Roland.
