Used M lens sources?
robinje
4:27 AM
I'm in the market for a used Leica wide angle lens. Besides FleaBay, which dealers typically have the largest selection and most reliable grading? I've checked KEH, Tamarkin, and a couple of others but I want to make sure I'm not missing the 'mother lode'!
You can always check BH and Adorama, their inventory turns pretty quick too. Also, http://www.igorcamera.com/leica_lenses.htm is always an option.
Im sure as more people see this thread you will see more sources.
I've had great luck with B&H, Adorama and KEH. All have good return policies. Good inventory changes quickly though. Recently returned a Mamiya 50/4.0 for a Mamiya 6 to Adorama because I was lucky to find the same lense in "like new" condition at KEH. I was outside of the seven day return policy, but I appeared in person after they were closed for a holiday. No questions or problems.
A few times I found their rating system to be very conservative and I felt like I got an exceptional deal(s).
Good luck and check the websites frequently. In a blink of an eye the good stuff/deals disapears quickly.
Cal
I've had great luck with B&H, Adorama and KEH. All have good return policies. ...
Recently returned a Mamiya 50/4.0 for a Mamiya 6 to Adorama ...I was outside of the seven day return policy, but I appeared in person after they were closed for a holiday. No questions or problems.
Thanks so much for the f/back; very much appreciated!
There is a lens on KEH I am interested in. Are they any good? Im in Australia so havent had anything to do with them before? They say the lens is LN-
KEH is pretty good for equipment rated EX+ and better. For EX and lower, it's a bit of a crapshoot, and I only buy that stuff from them if I'm willing to eat the 2-way shipping costs. Since you're in Oz, that would likely be expensive. But for an item graded LN- you should expect to get a literally nearly-new piece from them.
Ari
Ari
I was lucky to find a Mamiya 6MF graded in excelent condition and a hard to find 50/4.0 wide angle for a Mamiya 6 in LN- condition. The focus was stiff, just like a brand new lens. The Mamiya 6MF body was consevatively rated at excelent and should have been graded E+.
The turnover rate is very high. The good stuff disappears quickly. The other 6 body and 50/4.0 of lesser grades were gone the next day. Like I said I was lucky.
Cal
