Calzone
Gear Whore #1
- Local time
- 11:37 PM
- Joined
- Nov 11, 2008
- Messages
- 16,953
- Location
- The Gateway To The Hudson Highlands
Retirement is fun, but to make the most of it a lot of thinking is required that involves self-reflection.
I narrowed down to wanting a Hobie because of reputation, the peddle drive, and the ergonomics of buying a car-topper which I think will encourage it’s use and value.
Then I looked into buying used, but the updated features of the newer models are enough of an upgrade to discount the older ones where they might not be in the picture anymore. The new flipper drive has a feature where the flippers fold/collapse to prevent damage. The longer “Turbo” fins come standard that allow for higher speeds.
I love that this is a one man rig for the privacy and solitude. I also want to void buying more than I need. I have selected a Hobie “Outback” which is 12 feet 9 inches and weighs about 100 pounds rigged. The total capacity including the hull is 375 pounds, and know I only weigh about 150-155 pounds. Two rods and some tackle and I’m good to go.
I determined that the $30.00 surf rod to be useful requires a spinning reel, but I discovered that Van Staal high end reels designed specifically for surf casting in the Northeast are now make in China. This kinda became a deal killer for me because a small Van Staal reel is about $800.00.
For me it is like buying a Rolex no longer made in Switzerland verses a Rolex made in China.
I looked into the Penn “Authourity” that is submersible, sealed, and features 13 eagled bearings and the same drag system as used on the Penn Internationals for off shore fishing. Also made in China.
Then in my wandering I discovered Seigler a conventional reel maker who makes a trick CNC’ed “Small Game Narrow” conventional reel with a lever drag like an off shore reel that retails for only $400.00.
The small Van Staal I was interested in weighs about 3/4’ers of a pound, and the Seigler only 11.2 ounce. The updated trend is in lighter rods and reels because this encourages longer days of fishing and also more fun.
So the Jersey Shore helped me get to where I need to be. The narrow spool on the Seigler I already know is an advantage over the Daiwa Millionaire Tournament to prevent tangles and backlashes. The 7 foot Fenwick casting rod is still a very fine rig with the Diana Tournament reel, but that rod can be great for live lining and chunking bait because it has a fast tip and is designed to lobe up to 3 ounce weights.
In my research I learned that using 3 ounce pyramid sinkers on fish finder rigs is used in the stripped bass spring run in the Hudson River. Basically the Strippers chase the Herring up the Hudson till the dam in Troy. The new Fenwick rod I bought is perfect for chunking bait or live lining.
So the gear I’m buying is kind of an investment in myself, and the idea is not to cheap-out and buy to be “one and done.” Another way to frame this is to spend my money once with no reason to upgrade.
Because I have the skill to utilize a conventional reel I can avoid subsidizing the Chinese economy and avoid the evil that comes from cheap imports that have very real consequences.
I learned that if a kayak is stored where the sun shines on it, that the plastic can soften and structural damage occurs. So pretty much if I go used it would have to be a pristine one that was either garaged or covered. This promotes buying new. I have a hip-roof in my garage that utilizes no joists, so it would be pretty easy to devise a pulley with cleats to suspend the Hobie in unused space. EZ-PZ and for free.
So the thinking and planning is happening as the heavy lifting on the house has happened. Just one more contracting job left and that is removing a structural wall to join the tower room to the second largest bedroom to make a master’s suite. That should happen next month.
Cal
Cal
