The BD S2 with the 5cm S.C. 1.4 came a bit ago. Advance lever isn't auto returning but other than that it is in great shape. Think it just needs that mechanism cleaned and relubed slightly (the spring is fine) but I can't get the A/R ring out to get the top cover off.
The Yashica YF with the 5cm f1.8 Yashinon just arrived. Camera looks like it was barely used. Great viewfinder, though not 'life sized', and it has lots of room around the 50mm frame lines. I might mask out the 100mm lines at some point. I doubt I would ever use them. Added bonus an IXMOO works in it and opens properly. They don't quite open in a Tower 45.
