Reducing weight of Barnack combo
DavidC
12:42 PM
I've gravitated to a Leica IIIa with Summar lens for casual shoots but after lugging it all day still feel the oufit could be lightened with a lighter lens. Any suggestions?
Sounds like you may need to move to a fixed 3rd-party lens (non-retractable with less elements) where the center of gravity (CoG) is closer to the camera body?
I guess, compared to your Fuji behemoth!
For scale... there is a Barnack in this picture.....
Summar is already light f2 lens. If you don't need f2, you could get Elmar f3.5. Or Industar-10.
But if weight is the problem. New Rollei 35 AF is 242 grams.
I'm still waiting for a reasonable priced MS Optics Aporia 24. fortunately, I'm sort of patient.
Um, I have one...
The MS-Optics Aporia 24mm is an M-bayonet lens. It would be difficult to convert it to LTM! LTM mount registration is ~28mm, M-bayonet is ~29mm: this is why you can fit a 1mm thick mount adapter to put LTM on M-bayonet. The Aporia 24mm lens mount is so thin there's not much metal that would allow you to remove the M-bayonet and then add an LTM thread, like there would be on most other lenses.
I'd thought about that as a solution, but unless you can get them to issue a version of the lens with an LTM mount, it's likely not practical. Of course, it also means your IIIa would have a 24mm wide angle lens, and you'll need a 24mm viewfinder for framing.
G
Thanks for all the suggestions. I like the one about the 25/4 skopar. Hope one of Artisans group will come up with a ltm 28mm that is light and small in the future.
