dexdog
Sonnar B converted this collapsible Contax mount 5cm/f2 Sonnar to J-8 LTM about 15 years ago. While I Intially wondered why he would suggest this, I figured it was a OK given that I already had a number of Contax mount f2 collapsible lenses in good condition. In general, the LTM mount is easier to use on my Sony digitals given that many/most of the lenses I use are LTM, and it saves me having to haul around a Contax to E-mount adapter . Brian also emphasized the unique look that an uncoated lens gave on digital cameras. This lens is a real treat to use.The major issue with the 5cm F2 collapsible is finding one with a clean front element. Soft glass was used on the front element, hard glass on the inner group. 9 of 10 have surface damage, many to the point of being unusable. I suspect a combination of cleaning the front element and exposure to air. The uncoated 5cm F1.5- likely 1 of 10 suffers from scratches, hard glass was used.
Find a perfect 5cm F2 Sonnar- Keep it Forever. Mine- found on a Nikon M 20 years ago.
