Thank you for your experiment. My friend, a bookbinder, wanted to know if you can make such embossing tools for Leather with a 3D printer and if it works. Now I can at least give him hope.Not exactly an accessory but have just been playing with making 3D printed stamps to emboss leather. The front piece of leather on my Contax IIa case got lost so I’m looking at making a replacent. This is just a first try on a dead Agfa case.
Hi,Thank you for your experiment. My friend, a bookbinder, wanted to know if you can make such embossing tools for Leather with a 3D printer and if it works. Now I can at least give him hope.
Thank you for your valuable tips regarding size, line thickness and aftercare!! &!Hi,
Small lettering is out of the question though as I had to thicken up the lines a bit as the first attempt didn't 3D print well. The lines of the letters here are about 0.6mm thick and the logo is about 32mm across. I used ABS as it was what I had in the printer at the time but I suppose PLA would do. Once printed I sanded the block lightly before embossing to remove the 3D printing artifacts. I actually used a bookbinding press to apply the pressure so your friend is half way there.
That one modified for a screw mount Leica would be awesome. The Nikon AR-1 doesn’t fit, I testedSoft Release Button similar to the AR-1
I'm actually fed up with these soft release buttons. It was simply the challenge of drawing and printing one. They are not necessarily rare but expensive.
I haven't tested how stable the soft shutter release is if ya drop the camera to the ground, but it works. You might want to print with a more stable material than PLA. Fumble the stamp through the bottom part and glue it to the top part with a small drop of superglue. Due to the fine thread, print with as low a layer as possible.
I don't have a Leica. Not even a screw mount Leica.That one modified for a screw mount Leica would be awesome. The Nikon AR-1 doesn’t fit, I tested
The Nikon AR-1 physically fits the screw mount Leica (same thread) but the distance is too short. It means while screwing it on, it will immediately release the shutter and keep it pressed down. What I need is basically a longer version or I need to modify one of the AR-1 that I have.I don't have a Leica. Not even a screw mount Leica.
The easiest thing would be to have a Leica handy so I can draw the model accordingly.
What I have is a Nikon cable release with the union nut. I don't know if it fits a Leica.
The thread should be the same. As far as I can see from pictures, there is very little space between the thread and the collar around the release on the Leica.
The wall thickness of the Nikon cable release is only 1 MM, minus the thread depth, which leaves about 0.5mm of wall thickness. That's very very little for a 3D print. It could easily break under a slight lateral load. Then you have the piece of plastic deep inside the Leica release and it's difficult or even impossible to get it out again.
This means:
Can you tell me the inner diameter of the collar around the release? I'd like to make the wall as thick as possible.
Do you have a 3D printer yourself and can you print it and test it?
I would/could redraw the model and send you the *.stl file, then you can try out whether it fits and whether it works.
How much longer is longer ;-)The Nikon AR-1 physically fits the screw mount Leica (same thread) but the distance is too short. It means while screwing it on, it will immediately release the shutter and keep it pressed down. What I need is basically a longer version or I need to modify one of the AR-1 that I have.
I don’t have a 3D printer, would use the company in Kyoto again.
I purchased a 3D printed quick-load-style spool for my M2/M3, and it works great, plus makes loading much easier. The web site is www.cameractive.com.Does anybody have a design for the Leica M3 take up spool?
https://www.thingiverse.com/thing:5786850I would like to point out that black filament does not necessarily have to be light-tight!! This means that you should print with as many layers and perimeters as possible and perhaps wrap some black adhesive tape around it.
I take no responsibility, of course ;-)
