What have you just BOUGHT?
This is beauty!
Is the DOF scale indicator working smoothly? Mine was pretty stiff on a Exakta version. It was quite a challenge to cla the mechanism but it is well worth it.
Enjoy your new lens!
Yes, everything is super smooth, I love the two needles moving to show the DOF when you rotate the aperture ring, very original!
Dear Board,
I had read good things about the Chinon Bellami including a review by Mike Eckman who sung its praises, so I figured I wanted one. This outfit became available on eBay and was advertised as fully working so I figured, why not.
It arrived today and with fresh batteries in it all indications are that it is in fine working condition. I have Arista Ultra 200 loaded in it for its test drive. I can't get over how small it is. It's literally half the size of my wallet!
Regards,
Tim Murphy
Harrisburg PA 🙂
IMG_20250906_132314_MP by Tim Murphy, on Flickr
I finally bought the Artisan and Artist ACAM-3000 and it is excellent. Replaced nylon shoulder strap with a small Porta-Brace suede one. Holds a Sony A7CR with 24, 40, 85 lenses. I also have a similar Black Label brand bag that is slightly larger with a black interior and less padding (it's equivalent quality) that I switching to carrying large format holders, loupe and spot meter for 4x5.
Thanks for the tip. I read on another site it can also fall off the camera. Does it come loose easily?
I never once had that problem. But, probably wouldn't hurt to give it a slight clockwise turn whenever you use it, just to make sure it's snug.
The main problem I have is the rear facing glass getting smudged with fingerprints or oil or whatever. With the additional glass/air surfaces it can lower contrast of the viewed image if the glass isn't spotless. Not a big issue but I usually keep a few Qtips and some Isopropyl alcohol handy.
correction: I just checked and noticed that I use the gaffer tape on a diopter made by a different manufacturer. I also have the Light Lens Lab diopter, and it seems to have a bit more friction between the two halves, more firmly linking their movements, so I didn't feel the need to tape them together. 'Could still be done and probably wouldn't hurt anything, but it doesn't seem to be as necessary. Sorry for any confusion.
A bag of Acufine developer. I was originally planning to try Diafine, but no one in Europe appears to have any in stock at the moment.
I read this review of Acufine and figured I'd give it a shot, it gives me a decent "speed boodt" as well. Sorely needed here in Norway the coming months 🙂
I
I
Not Diafine, but many retailers have Bellini DUO Step. They claim it gives results identical to Diafine.
