It seems we have the same tast 😛Except for the M39 models, a black Zenit B is my favorite Zenit. The E‘s lightmeter is nowadays rather useless and it makes the camera „ugly“ 😗. The B is just perfect: simple mechanics, sturdy and heavy
What is the camera you intend to use the TC 16A on? I have two of them and are able to use them successfully on F90, F90x and F4s. They will not work without modification with Digital cameras except D2 apparently. Take a look here. Nikon TC-16A AF-TeleconverterThis week I bought a Nikon AF TC-16A 1.6x teleconverter, thinking I'd be able to use it in MF mode with my MF nikons and MF nikon/Tamron lenses, but it seems it was only designed for the F501 and to be used in a weird "you set the general focus distance and the TC fine tunes the focus" way. Over £60 at risk of disappearing if the seller won't refund it as there's actually nothing wrong with it except the silly design.
YES, YES, YES to the comment about the battery cover! Though I picked a nice black MR4 a short while back that was spares or repair, and it worked perfectly. Unfortunately I have about four in various states of disrepair.I bought two Leica MR meters that were priced well, one an MR and the other an MR4. The MR4 is working and seems accurate even without the MR9 battery adapter in it. The better exterior condition MR meter has been an adventure to get working.
It didnt have battery corrosion, but I cleaned the insides the meter started working The meter reading that is matching the MR meter but with issues. I can get it partially working with an SR44 silver oxide, but more often than not, it refuses to meter. Then I slip in an Alkaline LR44 battery and it reads and matches the exposure values on the MR meter. However the battery test function is also flakey and causes it to stop metering. May need to do more cleaning on it and checking all the contacts as I got the battery check to work when it was taken part, but when its put back together it doesn't seem to work and causes the meter to not work unless I remove the battery.
Oh the battery cover design is horrible on those meters.
I'm just wondering if other AF teleconverters can be used with MF cameras and lenses?C'mon now, it's not a silly design, let's be fair now, it's just that you're just trying to use in a way it wasn't intended to be used, it confuses a lot of people so you're not the first, you can use it as an MF convertor but it's messy and with MF, that's what the TC-14A/B are for.
TC-16A with MF Cameras
It does work with my D2X as well. [Nikkor QC 135/2.8]
An FM2n and an F301. I know it says "AF" on it, but I thought that as many AF lenses can be used on MF cameras, it would just be a case of bunging it on the camera and then putting a lens on it.What is the camera you intend to use the TC 16A on? I have two of them and are able to use them successfully on F90, F90x and F4s. They will not work without modification with Digital cameras except D2 apparently. Take a look here. Nikon TC-16A AF-Teleconverter
OK you are not going to be using it as it was intended. It's intended use was on early Nikon AF cameras converting the plethora of MF lenses to AF. It works as designed but certainly not to modern AF efficiency but it works. As I said I use two on F90, F90x and F4s, I have a number of none Nikon MF preset lenses with which they work and work well. Using the TC-16A on Nikon MF cameras it will work as a 1.6x teleconverter but you must set it up. Leon C has given you the relevant details, so will not be £60:00 wasted but if you were hoping for an AF function on a MF camera its not going to work.An FM2n and an F301. I know it says "AF" on it, but I thought that as many AF lenses can be used on MF cameras, it would just be a case of bunging it on the camera and then putting a lens on it.
it seems it can't be used just as an MF converter on an MF body with an MF lens.
Dear Plexi,
![20260213_110832[1].jpg 20260213_110832[1].jpg](https://rangefinderforum.com/data/attachments/146/146721-308df9945d2a927fd07cc976e24a77b4.jpg?hash=nq80Ij3AvA)
Great lens. Be sure to try it on your GFX. In 1:1 mode it has the same FOV as the SWC. In 65:24 mode it is the same FOV as the xPan with the 45mm.Yesterday I bought a Voigtälnder 21mm f3.5 Color-Skopar Vintage Line Aspherical (Type I) VM lens.
I'll take it out today and see what I can do with it. Should be fun!
Will do Tim!Dear Plexi,
If you would be so kind as to post a review of the meter after a few uses, I'm sure it would be welcomed by more people than just me! 😉
It someone else has already reviewed here on RFF then I'll have to look for it. I'd like to get a smaller modern light meter that does everything and doesn't cost a bunch of money. The Lumo seems it will fit that requirement.
Regards,
Tim Murphy
Harrisburg PA 🙂
