Nokton48
You are right, it's the contact itself that creates a processing defect. If you roll through the thread I think we have covered about everything that is available and some that is not available, but can be built.
You are right, it contact cannot itself that creates a processing defect. If you roll through the thread I think we have covered about everything that is available and some that is not available, but can be built.
I bought $50 minimum order from NDT and got four of their 70mm reels and a PVC rod to hold the reels. You can develop in the dark in small plastic buckets.
The NDT reel will hold 13 feet of film.
Nevermind. I figured it out. I used a changing bag and just went for it. I had already practiced with a dummy roll. There was no core with the film.
Sorry I missed your post 🙂 So far I have opened the 70mm HP5+ but have only loaded 24 exposures (220 equivalent) to use in the upcoming spring around here. Thanks for reporting this info as the 70mm HP5+ is in unusual packaging. Can you post some underwater photos after you test, that would be wonderful to see.
How do you guys store your negatives? I am unable to find sleeves or those plastic binder pages for 70mm. I'm thinking about using those sticky mounting corners to mount them on binder pages.
Nope I'd use Kenro which are European. Two years ago in UK dealers I had choice of clear acetate, glassine, or clear plastic. Since B&W I went with glassines. Kenro is wide enough to easily take 70mm strips. Recommended. Strips of three of course. Here's some in Germany
https://www.ebay.co.uk/itm/KENRO-Pe...987392&hash=item2ac8228478:g:rogAAOSwTmxcl40b
You can contact print these with 11x14 B&W RC paper, 11x14 piece of glass, lightbulb/timer for exposing, red safelight.
The shipping cost is ridiculous!!
Shooting 70mm ELM tests 24 exposure rolls 100 Planar 2 by Nokton48, on Flickr
Here I am test exposing three A70 backs, with the Hasselblad 500EL/M, with the 100mm T* Planar, one of my sharpest Blad lenses. Broncolor C171 Pulso Monolight 1/8 power measured with Broncolor FM2 Incident Flash Meter. Made 1/2 stop bracketed exposures around the calculated median exposures, rating Rollei 400s at EI 100, then original 1981 Plus-X (luscious and amazingly still good) rated at EI 50. Finally Kodak WL Surveillance Film rated at EI 250. To me this film is like a cross between Eastman XX and old Tri-X formulations. I'll bet it pushes really well for higher EI's. 70mm and a motorized camera is great luxury. Hasselblad used to call this combo the EL/70 which you could buy as a package from your local dealer. If you shoot Blad 70mm you should buy an EL/M and try this. The 24 exposure rolls can be developed in my Patterson homemade 70mm spool rack, I will prolly use ADOX Borax Replenished which I know works well with the WL Surveillance. Rollei 400s I have developing in Rollei Supergrain from Freestyle.
Will be good to see the bracketed shots. And I can adjust development if I see fit.
What I would like to see, are some 70mm underwater shots posted here, if possible.
The 500EL/M and 70mm sounds like the perfect combination Dan. Although, I would personally be prepared to sacrifice the ability to easily change screens by having a 500EL, if only for the benefit of knowing I am shooting 70mm with (basically) the same set up three guys called Anders, Borman and Lovell used, in 1968. That would be wonderful. 🙂Shooting 70mm ELM tests 24 exposure rolls 100 Planar 2 by Nokton48, on Flickr
Probably middle to late this coming week.
