Is there a way to control the chemicals in my processing trays when I am printing? Like to keep a steady 68 degrees. Looked on B&H and Freestyle but found nothing. What do most of you do?
Regards,
clc
We don't worry about it. Print processing is more tolerant than film processing, and since you do test strips for each print, the difference caused by temp will be corrected when you choose which test strip looks best.
