Thanks, Larry (and Robert too).
I bet you guys helped a lot of people in their considerations.
As we can see:
1. The right hand side where we usually hold and operate the camera isn't that much shorter
2. Plus it has the contoured grip section
2. And that grip section is actually taller than its counterpart on the old OM
3. The addition of the thumb-rest in the back
All these should make the handling easier and more comfortable. Probably except for those with very long fingers which would clash with the self-timer when using OM anyway.
So I don't buy the line of thought that OM-D is too small.
If you can use an OM comfortably, you will do fine with OM-D.
Even if that were not the case, getting the grips (mentally or literally
😀 ) should solve the problem nicely.
