rbelyell
much smaller than dslr, no question. deceptively larger than PEN series. taller and chunkier than X100.
tony
			tony
E-M5: 122 x 89 x 42mm
E-P3: 122 x 69 x 34mm
The former has a built-in viewfinder and actually measures shorter than the E-P3 plus EVF.
So I don't understand "deceptively larger". It is very slightly larger, but of course is weather-sealed and has a tilting screen. It seems to be to be a very nice form factor.
perhaps if you had both and put them side by side you would understand. perhaps if you personally carried each around you would understand. other than that, cant help ya'.
Well, you could help me if you at least tried to explain what you meant by the phrase I asked about. But you are not willing to do that, apparently. Instead, you suggest I spend a thousand pounds. Which is terrible advice, since even then I wouldn't gain any insight into your phrase which was, after all, yours.
Good luck with that attitude!
I'd imagine the e-p3 without the EVF would feel more streamlined. But the best comparison between the two would be with the EVF I think...
Perhaps you should go into a shop and compare them side by side, hold them, feel them, etc.Well, you could help me if you at least tried to explain what you meant by the phrase I asked about. But you are not willing to do that, apparently. Instead, you suggest I spend a thousand pounds. Which is terrible advice, since even then I wouldn't gain any insight into your phrase which was, after all, yours.
i used the word 'deceptive' exactly because published measurements do not properly convey how the size difference 'feels', imo. frankly, the OMD is totally asymetrical, so i dont understand how it can be measured as if it were a perfectly rectangular block. its pyramid shaped, with one side being a fair amount thicker than the other, and even sporting a protruding 'lens mount housing'. while the OMD looks small out of the box, probably because pictures of it prepare one for a larger machine, it simply does not feel, nor is it in fact, as svelte or pocketable as the PENs. i never measured them, just as i dont test resolutiion through test charts, but with both, i feel pretty confident i can tell the difference.
quote]
That's certainly small compared to a DSLR, but the camera I ended up with is the Panasonic GF3, with the new shorter 14-42 lens. The body dimensions are
GF3: 105 x 66 x 32
Including the lens and lenscap, the total depth is 63mm. This camera is so small that it looks quite silly with an adapted Nikon SLR lens on it.
The camera controls are simple and it lacks an EVF, but the user interface is extremely intuitive. If you are using an adapted manual lens on it, you touch the screen where you want the focus point, and it immediately gives a 10X view centered on the touch point, as if it were designed specially for that sort of application. If I am looking at the screen rather than through an EVF, again I can touch the screen to indicate desired metering and focus points, even in the automatic modes, something which would be inconvenient with an EVF. The camera is quite well made, and supports every exposure mode I have ever heard of, again with intuitive manual controls. I have not done much research on 4/3, but it does appear that with this camera, Panasonic did indeed accomplish "less is more".
Dez
GF3: 105 x 66 x 32
Only on RFF could a thread 25+ pages long be dominated by discussions of dimensions.
Or "which case, which bag, which strap ..." :angel:And we haven't even began in the earnest uh... discussing, about silver vs black 😀
Speaking of which, I'm rather surprised that the silver seems to be as popular (maybe slightly more) than the black from the hands-on images I've seen.
Indeed, I'm not sure any of my current bags are optimal for this new camera 😉Or "which case, which bag, which strap ..." :angel:
