best 35mm RF on the A7?
Has anyone tried the W-Nikkor 3.5cm/1.8 on the A7? I have looked around but no examples to be had. There's a a nice s-mount adapter available from the Head Bartender.... I would be over the moon to use my Nikon RF lenses on a FF digital body...
Taemo, that's quite a list of requirements you've got compiled there!
Generally speaking, performance, small size, and cheapness are NOT things that go hand-in-hand, especially not in the realm of RF lenses.
Personally, I've quite enjoyed the results I get from my 35mm f/1.4 Nokton MC. It vignettes like crazy and isn't the sharpest thing out there but it's got a nice signature and a unique "look". And I actually prefer it's output to (gasp!) the Summilux Pre-ASPH.
Other RF lenses that may meet your "cheap, fast, small(ish), good" requirements:
- VC Color Skopar (mentioned by someone before me)
- Canon 35mm f/2 LTM
- Zeiss Biogon 35mm f/2
- VC 35mm f/1.2 Nokton (version I or II, I personally can't really tell the difference between the two, can be found used for under $1k)
- Leica R-Mount lenses; 35mm Summicron or Summilux?
I am omitting suggestions like modern ASPH Leica anything, as those do not come close to meeting your sub-1k price tag.
If you were willing to ditch the "small" requirement, I've heard good things about the Samyang/Rokinon 35mm f/1.4, however it's SLR-sized. On the other hand it's a more "modern" design so if you aren't happy with the more "classic" performance of your Nokton I'm guessing you are looking for a more modern lens? The affordable vintage RF glass (like the Canon 35mm LTM) will be more prone to vignetting, CA, flare, and will generally produce lower contrast and less saturation in output; not necessarily a bad thing, but maybe not what you would want if the Nokton 1.4 is already not to your liking?
Personally, I've been extremely pleased with how the Nokton 35mm f/1.2 has been working with my A7R. It's a beast!
Here's a moonlit nightscape at f/2.8:
Wide open at night, illuminated only by a movie screen's glow:
Portraiture (F/2ish if I recall)
Group portrait at f/5.6:
Sure, the Nokton's a little heavy and big for an RF lens...but the A7/r/s isn't exactly tiny or light to begin with. I find the Nokton balances nicely on my A7R, and compared to comparable DSLR camera/lens combos (which don't even have f/1.2 lenses available!), the Nokton 1.2 + A7 is still relatively compact.
The CV 35/2.5 is OK in central frame and gets better as you focus closer, but for infinity landscapes I found the lens unusable on either A7 or R, because of the edges.
the 1.4 is much better, I found.
I have a Nokton 35mm f/1.4 MC right now and for the most part I'm very happy with it but I would like a sharp and distortion free RF 35mm as I find it the ideal focal length for travel.
Here's what I would like:
-small, light, compact
-f/1.4 or f/2
-ideally sharp wide open
-inexpensive (around $1000)
-will work on both A7 and M6
some of the lenses I have in mind
-35mm Summicron IV (150% my budget but I've always wanted one for the M6 and A7)
-ZM Biogon 35mm f/2
-Canon 35mm f/2 LTM
I wouldn't mind going with 40mm Summicron-C either or even Nokton 40mm 1.4 if they are great
Where´s the problem with SONYs 35/2.8 Sonnar?
https://www.flickr.com/groups/sel35f28z/
As much as we want to venerate magnificent film-based lenses, they simply don't shine in the digital domain. The flatness of the sensor and it's desire for perpendicular light rays demands 'tele-centric' designs. Based on the NEX6, my best results have been with Sigma 2.8/19, 30, & 60mm (28, 45, & 90) lenses (affordable). The CV 25/4 Snapshot-Skopar works well, albeit slow. Wide angle RF/LTM lenses, while having the simplest adapter interface, are especially problematic. I have gotten best results with the Fotodiox Pro adapter (a block of aluminum). The adjustable set screw adapters compromise parallelism. We're talking about miniscule dimensions (for example, the thickness of film is up to 30 microns, while the 'thickness' of the sensor is zero microns). Such a harsh lens/sensor interface leaves little leeway for lens 'signatures'.
True. but it's not just the sensor. The cover glass imposes a major limitation on the performance of many RF lenses on digital sensors.
http://www.lensrentals.com/blog/2014/06/the-glass-in-the-path-sensor-stacks-and-adapted-lenses
http://www.lensrentals.com/blog/2014/06/sensor-stack-thickness-when-does-it-matter
http://www.lensrentals.com/blog/2014/07/sensor-stack-thickness-part-iii-the-summary
Note that these measurements explain why the Leica 28/2.8 ASPH is a terrible performer on the A7 line, while the CV 40 acquits itself pretty well, and the Lux ASPH and CV 35/1.2 fall somewhere in-between…
Or not.
Used EOL'd bodies that start at $3000 aren't for everyone.
But you already knew that before you posted, I assume.
thanks for the suggestions, how does the summicron ASPH perform on the A7?
my concern with the Biogon and Summicron is that from what I've read, they don't perform as great as on a RF camera with smearing in the corners but then it might just be the internet over-exaggerating things.
I would love to get a Summicron IV, one of my dream lens for the M6 and A7 but would like to see more examples of it on the A7.
Might stop by the Camera Store one of these days and play with the 35 biogon and summicron.
here's the softness of the CV 35 1.4 at 1.4
DSC01813 by earl.dieta, on Flickr
which I don't really mind since my 1.4 shots are only for small prints.
but a little disheartening seeing the distortions, even at f/8 or f/11
Bora Bora colors by earl.dieta, on Flickr
Super sharpness is highly overrated in my opinion. These images you've posted are beautiful. Save yourself some $$ and stick with the Voigtlanders. I always thought the 35/1.4 Nokton and the 35/2.5 Color Skopar were truly excellent lenses for making beautiful images.
