Best 400ASA b/w film/developer combination for a novice.
Long shelf life and ease of use make Rodinal and HC110
excellent choices as developer for the occasional user.
They're the most economical, too! 🙂
Chris
Thanks everyone!
Just to summarise the suggestions--
Developers
Diafine 5
DDX 4
D76/ID11 9
XTOL 4
RODINAL 2
TMAX 1
HC110 3
Film(400)
AGFA 2
HP5+ 7
NEOPAN 3
TRI X 8
TMAX 1
DELTA 1
FOMA 1
Of course the combinations are legion,and it's great for me to research.The majority view seems to lie with HP5 and/or TRI X,combined with IDII and/or D76.
Brian.
Another vote for Neopan 400 (rated at 640) + Diafine. TriX + Diafine worked wonders for me, and also Fomapan 400 (rated at 800) + Diafine. Rating Neopan 400 at ISO 200 and pulling a stop in Microdol-X gives stunningly beautiful tones.
Another film recommendation for HP5+.
If you are just starting, I'd recommend liquid developers such as HC-110 dilution B and DD-X. Both capable of delivering nice results.
One thing at a time; liquid for now so that you don't have to deal too many variables that can affect your results - problems such as mixing powder, storage, etc.
T_om said:
It is hard to find something better than Diafine and Tri-X
Tom
Tom,
In view of the increase in speed,what speed would you recommend for Tri X.The Massive Dev Chart suggests 1600?
Brian.
dnemoc said:
Just rate it at 1000, 1600 I think will be too much. I don't know of any other developer which brings out details in TriX as crisply as Diafine, but then I've not tried too many.
As most of my cameras are pretty basic FSU models,I was doubtful that they could rise to the occasion at 1600,so thanks for the benefit of your experience.
Brian.
XRay,Toby,JL---
Thanks for the suggestions,as I mentioned initially,my brief experience some years ago was with Ilford materials,and I would feel good about supporting them again,quite apart from the excellent quality of the product.
Brian.
Brian,
I'd keep away from DD-X - the cheapest I've found it in the UK is £10.99 / bottle from Jessops (of all places). And it nominally mixes at 1+4.
I think the barrier will be just getting the first rolls done after a while away from this stuff.
I'd recommend Ilfosol S (£2.49/250ml) from Jessops and some HP5+ - it is very resistant to clumsy developing.
Once this hurdle is gamboled you can get stuck into ...
... this is why you shouldn't listen to people in the internet so much 🙂 I've changed my mind and gone for Agfa 400 and Diafine - eeek (for ease, mind)
kully said:
Brian,
Hi Kully,
I sort of expected a varied response from everyone on this---but coping pretty well,and not too confused.🙂
I will be keeping it as simple as pos. as you suggest.It will be HP5 OR Agfa as avilable,plus as straightforward and predictable a developer as possible.
I haven't darkened the door of Jessops for quite a while---I must have a look--no sense in paying for postage if avoidable.Also we do still have one more traditional camera shop left here,and they should be supported as much as possible if I can.
Hope the clear out is edging you towards that bike!
Brian.
IME Xtol is very good with Tri-X, Neopan 400, Neopan 1600, Acros, HP5+, FP4+, and Pan F. Tri-X in Xtol 1+1 rated at whatever speed is suitable for the conditions, using the times given in the Massive Dev Chart, is a good place to start.
Ian
