Ezzie
E. D. Russell Roberts
Hi Paul. All things are equal apart from the development itself. To start with the other stuff first. I use 1min water stop bath, fix 5min and regular wash. If you mix things every time you develop a film it will add considerably to your cycle. I don´t do this. I pre-dilute the three main ingredients triple strength and measure out 3 equal measures when developing. By doing this I need not wait for the powders to dissolve, settle and cool down. If I did it would add another 15-20 minutes. The soda generates heat, and the coffee needs hot water to dissolve properly. I avoid all this. In doing so preparations are equal to regular developer. So the only prolonging event is the development itself. Agitated development is in the region of 15 minutes. A long answer, but the short answer is 8 or 9 minutes!
How long do the dissolved mixes keep? Well I´ve got compressible bottles with sodium carbonate and ascorbic acid that are in their 8th week, and two films developed a couple of days ago, you´ve seen scans from one. The coffee mix however will keep anything up to 5-6 weeks if kept cold and airtight. It works still, but I suspect mould in the mix is not desirable. 😉
Regarding potassium bromide as a restrainer. Yes, with faster films you will need it to inhibit haze. However TMAX100 needs it not. I use a very small amount out of habit, and because my development times are calculated with PB in mind (it slows development a tad). But you need not. TMAX 400 however would need something in the region of 1.5g/l developer.
Feel free to ask more. And follow my blog link, its mostly Caffenol related.
