Darkroom Renovation Phase 1
Kodak Blotter Roll Dryer 1 by Nokton48, on Flickr
Kodak Blotter Roll Dryer 2 by Nokton48, on Flickr
Yesterday I made this Kodak Blotter Roll Dryer, yet another Peterson's Photographic home darkroom project. I have some old fibre paper I want to start testing. This is a quick way to dry it. Right now the dryer has a 100W heating element, which is interchangeable. Also I want to add a switch and a timer for this unit. Adding some filter material is a good idea. Gentle dry heat is the result so far.
2nd Omegalite rebuilt and Petersons Film Washer by Nokton48, on Flickr
Petersons 16x20 Matte Fiber Print Dryer by Nokton48, on Flickr
Three unfinished projects I have been working on here and there, as I have time. Two Omega Omegalite 4x5 heads (both trashed) combined into one perfectly working unit. First unit had a bad transformer, bought the second unit for parts. Attaching some adhesive foam rubber to the bottom, and it's finished 🙂 Good as new and cheap!
Second project is Petersons Photographic Rapid Film Washer. All plastic pipe is cut and tightly fitting just needs glued. Shown with stainless steel rod I bent to hold eight 120 steel reels (my biggest Nikor tank).
Third project is Petersons Photographic 16x20 Matte Fibre Print Dryer, all wiring completed except for the power cord. Four 640W wired in series pulls 600 watts, so I will keep the power cord short in length
Anybody know where I can get 16x20 photographic blotters, with muslin one sided? Been buying the plain blotters they sell cheaply at freestyle.
After the first of the year, I have a really big printing project coming up. Material from twenty five years ago.
Wratten 47B & 58 for split VC Printing by Nokton48, on Flickr
I have three enlargers with Diffusion Heads I like to use. I just reworked these old Omega Under The Lens Filter Holders. To split print on VC paper I simply put the Wratten 47B or 58 Gel Filters on top of the bolt heads. Simple and easy, and it works with my enlargers.
Now I just need to spray these silver ones with Krylon Flat Black paint and I am ready to go. I have been using graded #2 RC paper to print my negs, (I think of these almost like enlarged 4X contact prints, no embellishing at all) when I go back I will split print the best ones onto fiber paper.
Darkroom renovation 2 by Nokton48, on Flickr
Darkroom Sink Finally Plumbed 2 by Nokton48, on Flickr
E3 Finally Installed by Nokton48, on Flickr
Washing and Drying Side Sink Preinstallation by Nokton48, on Flickr
Latest Darkroom Renovation 3 by Nokton48, on Flickr
It's been a good year. I have gone from a primarily storage, and film loading room, to a real darkroom! Work will continue after the first of the year, as funds free up.
More heat, plumbing, more electrical, and work tables are future projects.
VC Contact Printing Source by Nokton48, on Flickr
I saw that Tim Layton built this unit, so followed his lead and I had fun building this. The ulility light was $10 at Home Depot, I removed the clamp mechanism. The box is made from foam core board and masking tape. I put my Multigrade 6x6" #00 & #5 variable contrast filters in cardboard frames, so I can change the filtering out by touch, under the dark safelights.
I tried a 7.5W bulb, amazingly way too bright for RC VC paper. So I ordered ROSCO ND sheets from B&H, in .6 and .3 densities. About a thirty second or longer time is what I am looking for, so I have time for burning and dodging.
The four suspension wires keeps the box level and keeps it from swinging around in the dark.
Garden of the Gods 1 by Nokton48, on Flickr
First attempt at VC contact printing with the new unit.
8x10 XRay Dev Hanger by Nokton48, on Flickr
For use in my 8x10 Sinar Norma, I have some ERA 100, some very old HP5 (not+!) and a fresh box of Ilford Commercial Ortho+ I just got from B&H. $5.16 per 8x10 on the Commercial Ortho+.
I want to try XRAY film, so I bought 100 sheets of Fuji 8x10 HRU on Ebay. I just cut down this Kodak 8x10 Film Hanger, so now it fits in a Patterson 8x10 tray. Has anybody here ever tried this method?
I have a gallon of Acufine mixed up (and replenisher) and I be giving this a go soon.
40 cents for an 8x10, 20 cents for a 5x7, 10 cents for a 4x5 sheet. Now I will be able to play under the safelights.
Way back, it was hand processing a stack of 6 sheets of 4x5. With your single sheet rig, the only thing to watch for would be processing variations induced by the frame during agtitation cycles.
Yep I'm wondering about that, too. XRAY film is dearly tender when wet and VERY prone to scratching. Hence, the hacked hanger method, will give it a go soon. It does have flow holes all around, maybe that will help, maybe that will be a problem? Maybe a bigger tray is needed?
You touch this stuff with your hands and the emulsion is marked.
Are you agitating by rocking the tray?
If so, maybe try rotating the hanger 180 degrees at the end of each agitation cycle for the duration of development.
The XRAY film arrived, 100 sheets 8x10 green Fuji UT for $42 including tax and shipping. Mucho cheapo.
It's super delicate, blow on it and it will scratch. Tried a test sheet in daylight Patterson 8x10 trays, it put a nice smudgy scratch right down the middle of the sheet.
It scratches easily too when it is dry. I just bought four smooth bottomed CESCO 8x10 trays, over on LFF forum they say that is the way to do it. We will see.
XRAY film is ortho and gives your photograph an "arty" tonality. Good for alternative processes, but I'm printing silver.
8x10 silver gelatin fibre contact prints would be the goal. 8x10 and 5x7! 🙂
Thanks Saul! I'll try that. Giving up on the hanger idea, I'm told that the film sags in the hanger, and still scratches :bang::bang:
8 minute development in Rodinal 1:100 seems to be a good start.
Contrast builds up super quick with XRAY film.
42 cents for an 8x10 Fuji XRAY. 21 cents for a 5x7 Fuji XRAY. 10.5 cents for a 4x5.
First test 4x5 Sinar Norma Handy by Nokton48, on Flickr
First test 4x5 Sinar Norma Handy 2 by Nokton48, on Flickr
First test of my homemade 4x5 Sinar Norma Handy. This is hand held 4x5 camera, with a 65mm F8 Schneider Super Angulon lens. Viewfinder is a 43mm model for the Mamiya 7. Made from original Norma parts and some home made parts.
Very expired HP5 (not +) developed in JOBO with straight Acufine. This particular film has high base fog, and little shadow detail. Want to repeat tests with fresh TMAX400 in the Acufine. Using this camera requires as high a speed film as is possible. Very fun to use this. Lens always focused to hyperfocal distance for max DOF. 1/125 at F11 hand held No center filter used
Sinar Handy with Strap and Cable Extension by Nokton48, on Flickr
Here's the completed camera.
Focus Test Makiflex Std Super Cinephor F2 by Nokton48, on Flickr
DSC01430 by Nokton48, on Flickr
Focus Test with Makiflex Std F2 B&L Super Cinephor Motion Picture Theater Projection lens. Expired 4x5" Ilford Commercial Ortho rated at EI 50 Test target 45 degrees to wall in my studio. 6 seconds at F2 Focused on central dot. Processed in straight replenished Acufine 15 minutes tray development by safelight 65F ambient 8x10 #2 Aristo RC print Multigrade developer. Full Makiflex 9x9cm image and full 4x5 image printed full frame.
I'm diggin' this lens for pictorial work.
