He is going to find he will need a few cross supports for the belly of that sink.
Sanded Ply is not very stable. It has a relatively low ply count compared to thickness.
I would reccomend 3/4 MDF over the more expenisve Sanded Pine Ply he is using.
One thing to note, if you paint/seal any surface on a wood project, you need to seal the entire project! Leaving the underside bare wood will cause moisture to collect under your finish and cause it to fail. This applies to stain/paint/sealer.
My brother and I made our first "sink" when we were 16. It was a 150-160gal propagation tank we made from wood to grow salt water Coral. We sold the coral to a pet shop a few citys over. We used a product similar to the link below. I cant remember where we got ours, but we had it custom colored Sea Foam Green.
https://liquidrubberusa.com/collect...rproof-sealant-coating?variant=12132863475805
A local alternative can be found at Home Depot in either Gray or White. It is made by Henry and is called "Tropicool 100% Silicone". An important distinction is in the two products offered.
Product 887 will work fine for a project like this, but if you have any doubts spend the extra money on Product 885 which is "Ponding Resistant" basically that means it can have water sitting on it indefinitely. I re coated our Motorhome roof in the 885 and its some tough stuff! Dries SUPER QUICK (15min) and sticks like a Mother****er so do not wear your sunday clothes. lol
Cant wait to see your sink build!
Edit: Funny story about the motor home roof. I started it late in the afternoon after spending the better part of the day cleaning and prepping the roof. Not 10 minutes after getting off the roof it started to pour buckets of rain to my absolute dread! After about 2 hours of hard rain I had to go check on it. Spot light in hand dangling from the ladder it looked so fresh and clean! The stuff is amazing! A little water did not hurt the curing. Its nearly 2 years old now and holding up as good as day one. Cleans up nicely with a little soap water. I plan to put a fresh coat on this spring just for giggles.
