narsuitus
The main reason I did not use a prewash was because I was working for a newspaper and the film wet time had to be kept to a minimum in order to make deadline.
Some of Ilford's recommendations don't, and won't work all the time. Like Prewetting and Use of Hardening fixer plus short washes.
Apparently Ilford forget that there are places in the planet where "room temp" is around 30-35C and that the tap will spout water at about the same temps.
It's one thing to temper the processing solutions (dev/stop/fix) at the recommended temps, but it's an entirely different thing to chill wash water as well. Possible but not practical. Ilford advocate the use of non-hardening fixers and short washes. That's sound, since little fixer is retained by unhardened emulsions.
But do that in the tropics, and the emulsion frills or crazes. Seen it happen. Not just with the oldfashioned Efke films, but with Fuji Neopan, and Ilford Pan F as well.
However, using hardening fixer makes the emulsion tougher. And washing the film even in water as it comes out of the local tap doesn't cause their gelatin to swell too much or abrade easily. Washing is longer than what Ilford now say; but since the water here is warmer, the cycle isn't as long as the 30-60 min routine for the 15-20C taps in colder climates.
And prewet here HAS an advantage- it prevents the 'hot' film, reel, and tank from warming the cool developer. That's the reverse of what the fussy tea lovers do in preparing tea - warming up the pot first before putting in the leaves. The English know this well...😎
A litre and a half is not a very big barrel. That's one of the reasons they recommend this wash technique.
No-one is going to argue that your technique doesn't work for you.
It is widely known that very high temperatures can cause film processing problems. I don't think Ilford has 'forgotten' anything, including this.
Some films have an anti-halation dye that dissolves out into the developer, staining the developer.
The issue of pre-wetting or pre-washing film has come up in several threads recently. This got me thinking. I learned to process film 20 years ago, and never heard of the technique of pre-washing film until I started processing film at a small high-end black and white boutique lab in NYC eight years ago. The guy who founded the lab trains everyone who works there in his methods of processing film, regardless of their experience. His methods include a pre-wash in plain water of all films to be developed in standard developers, except where contra-indicated. The way it was explained to me, pre-washing helps in a variety of ways, including stabilizing the the film at the development temperature, and swelling the emulsion, preparing it for the developer. The idea is that this results in more even and consistent developing, and slightly finer grain.
Regardles of the precise science or voodoo here, I have continued the practice ever since. I now run a small lab offering boutique black and white services to a few other photographers, and I pre-wash all my own film and all the film I run for my clients (except films that will be run in two bath developers like Diafine which specifically indicate not pre-wetting).
So that's what I was taught, and this has been my experience. I'd like to know your thoughts on the practice, and get an idea of if and why people do this or don't do it. Thanks.
(Edit for clarity.)
Interesting. Most of the books I've read reckon it's a waste of time with most films and developers. We must read different books.
-Ansel Adams "The Negative"
-Henry Horenstein "Beyond Basic Photography"
-Jack Coote "Monochrome Darkroom Practise" who doesn't specifically recommend it but briefly discusses the reasons its done. Coote worked for Ilford for years. Its interesting to note that he does specifically recommend it for XPI400 (now XP2?). There have been many threads from people developing their own XP2.
