tennis-joe
This thread made up my mind from not investing in a CLE.
It has been several (3-4) years but a friend had Sherry at Golden Touch overhaul his with good results.
Dave Easterwood has repaired and adjusted my CLE several times. It would be worth asking him about yours. Lack of parts can be a challenge for sure, but, the CLE shares some parts with other Minoltas and Dave has 3 storage units of parts. Sometimes fixing a camera amounts to cleaning a dirty contact or adjusting something rather than putting in a new part. I love my CLE.
Dave Easterwood in Chelsea Michigan. dave@davescamera.net (734) 433-2640
Hope this helps.
Steve Rosenblum
Try this:
"Open the back of your CLE (make sure no film in camera ofcourse) and also remove the lens. Turn the camera ON and GENTLY try to move the shutter curtain with thumb and pointing finger in one way or the other. Perhaps this can release the shutter mechanism."
This was originally posted here 8 years ago. It worked for me, and I have had no problems with my CLE since.
I think the problem or dilemma is that it takes time to strip it down and then replace everything including a broken part and no one is going to pay for nothing more than the knowledge that it needs an unavailable part.
From the repairers' point of view it's just not worth doing because, with a few exceptions, you can't do a repair any other way but a complete strip own.
Of course, you could pay for so many hours work in advance and offer to let them keep it for parts if not possible to repair...
Regards, David
Hope this helps.
Steve Rosenblum
Hope this helps.
Steve Rosenblum
Okay, this thread triggered a memory-I bought a used Nikon FG very cheaply. It too wouldn't fire. I knew it had a electronic shutter....I left it on for about an hour and it fired. I thought, "okay..." I left it on another hour...then it'd fire 3-4 times. I figured out that the capacators(sp) needed to be reformed like the caps in a flash that hasn't been used in a long time. I left it on overnight and then tried it the next morning. BINGO !
Your CLE might just have the same problem...buy some cheap MS76A batteries and see if this works.
I have left my CLE on. Thing is, it turns off after a few seconds if there is no contact on the shutter button, so not sure if this would work. (hasn't with mine)
