raid
Dad Photographer
I understand the the 16mm Holigon was an optically an improvement over the 15mm.
I recall that Erik has said so about the 15mm and then the 16mm development.
Yes, I was talking about the Hologon 15mm and 16mm. The 15mm Hologon was introduced at Photokina 1972. The 16mm Hologon was introduced towards the end of the 1990's as lens for the Contaxes G1 and G2. The 15mm had 3 elements and the 16mm 5 elements if I remember well.
Erik.
The middle element was a challenge for Zeiss. Cenering of the elements, only 3, will be key. Good of LLL to give it ago, lets see what happens.
Are you referring to the 15mm Hologon for the Leica with respect to 1972? The Hologon first came out as a complete Zeiss Ikon camera which I recall from reading about it in Modern and Popular Photography magazines when I was in High School (graduated in 1972) so maybe a few years earlier for the introduction (when we were in the single coated era). I seem to recall a large format version of the lens as well. Three elements may be better for single layer coating. The middle element of the 15mm may be a challenge for LLL to make?????
A Hologon replica by its very nature would not be digital friendlly. Would need to get a retrofocus voigtlander if you want that.
Well, it will be interesting to see if I ever get a LLL Hologon 15 replica to play with. I would probably have to use film, but who knows?
I have heard nothing of this from Kevin in over a year, when he and I last discussed Hologons. -- sort of in passing. So, we will see.
And Raid, I have the CV 15 I, which I have been told has been considerably improved. I am not even sure I ever used it on a digital body, except for the M8, which of course had the field cut.
I'm curious, aside from the size, what will a Hologon with a fixed ƒ/8 aperture and a central ND filter further cutting down the light, provide the user that betters the CV 4,5/15 v.III?
As I said in my Viewfinder article, the link to which is posted above, images with a Hologon tend to look like those taken with a less-wide lens (like a 28mm) in terms of sharpness and lack of distortion (other than the angle itself would make) toward the edges. Very good contrast and decent control of flare. A retro focus lens like the CV can be very good (I only have Version I), but there is something about non-retrofocus lenses that is subjectively and perhaps tangibly different.
The CVs - 21 -15 -12 -10 are rectilinear.
I have a really decent Jupiter-12 35/2.8 in LSM that Tom Abrahamsson gave me. It is a Biogon copy, non-retrofocus, and gives loverly images. I'll take a few this afternoon with it, if I can.
L1004624-Edit by woodswoman57, on Flickr
L1004625-Edit by woodswoman57, on Flickr
L1004626-Edit by woodswoman57, on Flickr
L1004627-Edit by woodswoman57, on Flickr
L1004630-Edit by woodswoman57, on Flickr
L1004631-Edit by woodswoman57, on Flickr
