pauld111
I bought a used Flextight X1 from Ffordes, in like new condition. (I cannot justify this purchase with any logic but that's another story.) My problem is that in the last day I have only been able to get the scanner to be recognised once, and I used it for a few joyful hours. I then thought I would restart everything and try my luck again, just to see if I had the process down pat - but to no avail. What is the correct process of turning on the machine and using the program? What I tried was: turn both the computer and scanner off. Turn the scanner on but leave the door up. Turn computer on and log in. Open scanner door. Load software. But this does not work as it does not automatically acknowledge the scanner. (I just cannot remember what I did to get it right the one time). I am running a pc with Windows 7 and am using a firewire 400 6 pin cable from scanner to 4 pin to computer. Any help would be much appreciated. Thanks
