Fotohuis
But the Microdol-X receipt is not that complicated. 😀
I can recommend PC-TEA from Pat Gainer. In 1+50 it works like Xtol 1+2.
D23
Water 1500 ml
Metol 15 grams
Sodium Sulphite 200 grams
Water to make 2 liters
Has a tendency to develop without blocked highlights.
Worthy of experimentation with Foma
Thank you very much for this recipe. However, I had problems with detail-less shadows.
Then the answer is to -increase- exposure. Try it and see what happens.
I almost always shoot an extra frame with 1 stop more. Often it's the best frame. Frequently I'm guessing at the exposure anyway with no meter
Too contrasty means too long development. Cut 20% and see what happens.
I only like soft-working developers with FOMA. Easy to get bulletproof negs
Thank you, very good idea. I will shoot these films at ASA 50 (18 DIN)= pulling 1.5/2 stops, and shorten the developing time (e.g. 9 mins in Rodinal 1:50). Before mixing my Xtol-clone. I will see the results.
Fomapan 200 in 120 = meh
I recently shot some rolls of Fomapan 200 in 120 format, and developed them using the same procedure I use for 35 mm (HC110 dil h for 7 mins at 20C). I was underwhelmed and disappointed at the results. Blocked shadows and little of the subtle mid-tones that I love in this film in 35mm. Anyone else shooting Foma 200 in MF? Interested in your thoughts abourt this film in 120.
Plaubel Makiflex 180mm F2.8 Sonnar Foma 200 Microdol-X Makiflex 180mm Sonnar Foma 200 by Nokton48, on Flickr
