Lss
I have recently purchased a Pentax 67 body only. My first lens for this system (105/2.4) has just arrived, so now's finally the time to test the camera. Unfortunately, there is a problem.
Without film in the camera, the frame counter shows the big dot left of zero. After I open the back cover, I can rotate the frame counter to wherever I want and as I let go off it, it either stays where I have set it or returns to the big dot depending on whether I closed the back cover or not. I guess this is all normal. I can thus test the shutter following the process described in the manual.
The problem
Once I load film, I can advance the film as much as I want, but the frame counter never moves and the shutter does not get cocked. If I do the trick above with film loaded, I can cock the shutter and I assume take pictures fairly normally - however, the frame counter never moves from 1 (or wherever I manually set it). This is not really optimal, since I don't know how many times I need to advance the wind lever to get to frame 1 nor do I know how many exposures I have left. I guess this can lead to missing photos in the beginning and even end of the film.
Has anyone experienced this? Any tips?
I'm using 120 film and have set both the counter and the pressure plate for 120. The battery is fresh. My camera did not come with the shutter cocking key, so I can't test with that.
The problem
