I don't use autofocus. Ever. I don't want to look at pixels until they're on my Mac. I like happy accidents, and sometimes I like blurry subjects. I also have disposable income for a camera that will satisfy all these strange needs, and I can't be entirely alone in all this. Fujifilm! Is the X100 my camera?
I may have missed it, but why don't you like the M8 or M9?
I do not really understand what do they mean by the 90% coverage (the viewfinder is larger than the image taken, so ... ?),
You're probably right, Matus. I don't even think I can picture in my head a VF with such a wide angle. Are there other examples of similar viewfinders that I may have put up to my eye sometime in the past year for comparison? 🙂 dSLRs? P&Ss? Fujifilm disposable 35mm cameras?
I guess the easiest is to check low-end DLSRs as these are around 0.5x (after the 1.5 crop factor for APS-C sensors and m4/3 camras):
Nikon D3100 - 0.53x
Canon 550D (T2i) - 0.58x
Pentax K-X - 0.56x
Nikon D7000 - 0.62x
Panasonic G2 - 0.7x
Panasonic G10 - 0.52x
Samsung NX10 - 0.57x
Olympus EP cameras with VF-2 finder - 0.57x
It's not at all difficult to imagine.
Nikon D3100 - 0.53x
Pentax K-X - 0.56x
Nikon D7000 - 0.62x
Panasonic G2 - 0.7x
what it means is that you only see 90% of what will be in the picture taken. Most budget DSLR's are 95% but with a DSLR you see exactly what will be in the frame, but with X100's 10% of the picture out of the frame and factor in the inevitable parallax (which is inevitable when you don't look through the lens), i see why Fuji has gone to the trouble of including the EVF through the OVF as well.
Actually, I think this may have been a communication error. I believe the 90% coverage thrown around refers to the OVF and not the EVF. The OVF has framelines and it makes no sense that these framelines would be placed at 90% of the frame. Instead, I think they meant to say that, with the OVF, you see an extra 10% around the framelines but the framelines themselves represent 100% of the image that the camera will capture. My interpretation, at least.
The OVF has an optical magnification of 0.5X and is independent of the EVF. It has a horizontal FoV 33% larger than the 23mm (=35mm) frameline or ~72.5 degrees...enough for a 26mm equivalent lens at 100% coverage. [From my own photogrammetric measurements.]
All [Leica/Zeiss...] RF framelines are smaller than actual coverage...~85%; and coverage inaccurate...dependent on focal distance. [A Leica 35mm frameline is actually 40mm in coverage and offset somewhat at close focal distances.]
The X100 frameline is claimed to be tighter...at 90%. The firmware generated frameline graphics is parallax compensated [based on lens focus ring position...and can be instantly recalculated with changing focal distance] and thus also more accurate [not set a 1m...].
The EVF sees what the sensor sees...100% coverage and accurate. At 100%, the EVF view is 11% larger than the 90% OVF frameline. A graphic illustration is available in the X100 web site. The EVF is modern ground glass and much finer. [All sorts of focusing-aid ideas could be added later...via firmware updates.]
There is no focusing aid for the OVF, except AF-S and AF-C.
Earlier, Brian Sweeney had thought an optical parallax-wedge [Leica RF style] could be implemented. I suggested an easier method might be to also project from the EVF a focusing patch...no hardware, no adjustments needed.
Yes, the extra-wide FoV of the OVF could support wider lenses, and if one also accepts 85~90% coverage...~24mm equivalent. The EVF will take care of itself. If longer lenses were added, a screw-in eyepiece magnifier could make the OVF frameline larger...Leica 1.25X or 1.4X style. Even Hong Kong suppliers had equivalent offerings.
