yup done that, not quite sure where the fun comes in though!. The meter does not calibrate to the E for empty, falling some way short fo the ideal, as we all do 😉
Its only fun if you get the satisfaction of it working!
Try to calibrate another dial to see if its the dial itself . My favorite dial to calibrate is the remaining shot dial. Try that one even if it doesn't need it . Just change it to something else then change it back if needed. This will prove if you are doing the procedure right or not.
I believe others have found that sometimes you have to keep repeating the calibration procedure. After each run a dial will reset nearer to its correct position until after several attempts it's OK.
