raid
Dad Photographer
William,
It is like roulette when buying a J3. I paid as much to Alex-Photo [I think] but got burned.
The lenses that will be re-tested:
Two CZJ and CZJ
J-3 93 and J-3 90 and J-3 88
Nikkor 45 and Nikkor T 12
Two CZJ and CZJ
dexdog
Roland,
What is an R-Sonnar? What does the letter R stand for?
Raid, according to Roland and others, the R means that the lens was used to make x-ray images in the years following WW2, as part of a tuberculosis screening program in Germany. According to information I have been provided by kind RFF members, my lens was originally produced in 1942 in Contax mount, and later remounted in LTM after the war.
raid
Dad Photographer
Mark,
I was unaware of this fact. Your lens is rare based on this inormation, isn't it? Do you know whether this particular lens differs optically from the regular Sonnar?
raid
Dad Photographer
I have just completed an additional roll on seven lenses that did not do well in the last flare session posted above by Roland. They were three J-3, two CZJ, two Nikkors,and as a control lens I used the CV Nokton [not the Summilux but a CV].
I did not shoot into a bare bulb light again, but this time I had four lit candles.
I had a piece of paper taped close to the target point with lens information for each negative. The four candles were placed behind each other at a small distance. I want to see the candle light as OOF.
I hope that the test comes out well.
Aperture settings were: 1.5-2.8-4.0-5.6 at speeds between 1/15-1/2 of a second.
raid
Dad Photographer
I need to mail out the lenses after this weekend.
This is the last weekend for testing.
raid
Dad Photographer
Here is one test image for taste; it comes from the follow-up test on the seven lenses that showed some excess flare in the last batch of images shown by Roland [above].
The focus point is the cross hair that is sketched on the sheet of paper.
The candle on the left should be also in focus. The rest of the candles were placed behind the focus point.
At one stage, I had tomove the nice vase away from a candle since it was getting smoke on it.
Lens: J-3 with last two digits being 93.
Exposure at f 2.8.
Exposure at f 2.8.
raid
Dad Photographer
My control lens was the CV Ultron.
Here is an image at 2.8.
Can you see a difference?
raid
Dad Photographer
Last image shown here is a Carl Zeiss Jena at 1.5:
ferider
Thanks, Raid !
They do behave differently with candles than with a 60Hz light-bulb, don't they ! (rather pretty and less flare if you ask me).
Roland.
Roland.
dexdog
Interesting results- similar on flare, close in resolution, although the CV is clearly the best. Thanks Raid and Roland!
raid
Dad Photographer
I like the results better based on this last test. There was no fan turned on [and I was sweating], but the candle light sure is unstable.
raid
Dad Photographer
I will mail out all lenses this Monday.
Please email me or pm me regarding the amount of insurance coverage that you would like your parcel(s) to be covered with. You can pay me back later.
Thanks.
Thanks.
raid
Dad Photographer
Thanks, Raid !
Roland.
If you focus on the candle on the left part of the images, you see that the Zeiss and the Ultron has a smaller area of halo around the candle light as compared to the halo area for the J-3 lenses.
raid
Dad Photographer
I might as well add an image taken by the Nikkor at 2.8:
raid
Dad Photographer
It seems that I complicated the lens test by using a low heat bulb in the flare test. With candles, things are clearer.
I will soon go through a "lens withdrawal" phase that can be painful!
No more lens tests for the next six months or so.
I now have plenty of images to post gradually in separate threads here.
raid
Dad Photographer
Here are a few LTM/M lenses at 2.8:
1. Canon 50mm 1.5:
2. J-3 Nr. 90 at 2.8:
3. Here is the Zeiss ZM at 2.8:
4. Lastly, here is the Summilux image at 2.8:
1. Canon 50mm 1.5:
raid
Dad Photographer
I find the Nr.90 J-3 to be an excellent example. This shows that finding the right J-3 can result in a wonderful and fast lens at an affordable cost. I don't know why the Canon 1.5 looks soft.
raid
Dad Photographer
its because the focus is on the earrings
I meant to say that I don't know why the focus point [the eyes] is soft even though a used a heavy tripod.
edit: jasperamsterdam's posting vanished.
Cutly
Hi, from which year is that J-3 ? (two first numbers ; I understood "90" are the two last?)
raid
Dad Photographer
This is Robin's J-3. I handed it back to him 90 minutes ago. The production year may not be the single factor in choosing a J-3 since my 1957 J-3 is not as clean and William's 1957 J-3.
Back to your question; the Nr. 90 J-3 was made in 1973. I used the last two digits to keep the 30 lenses apart.
