68degrees
Do you use the holders or do you use glass?
I just got my Epson V700 today,,,
and I Tried the Silverfast software 1st.... You have to frame each negative manually..
The Epson Scan Software will automatically select each negative, and frame them and number them.
you can then select each negative to adjust the histogram etc... and then when you are done, Select "ALL" in the Preview box, and select SCAN, and where you want to save them.. you can select your DPI and File type also, along with a Prefix that can be a Job Name, or whatever...
It will scan all the negatives with ONE PASS! and save them with a sequential number also.
So, it could software dependent also by the manufacturer
I know this is a bit late 😉, But for future readers, it may give another option, if they might consider the Epson V700, V750. :angel:
