Leica 5cm Lenses: Which would you recommend?
It is becoming quite clear that the Elmar 3.5 and the later Summitar and collapsible Summicron are the most popular here. The Summar is skipped for some reason.
Under ideal circumstances the Summar is a killer. But it flares and wide open it is soft. I think a good coated Summar with a round diaphragm would win a a high place in the top 10 of 50mm lenses.
Erik.
Erik,
There used to be a place which coats lens elements, and then a Summar could be coated as you want it to be.
Raid,
Do you know such a place? I once heard about a place in Ukrania that did coating on old lenses, but I think I would rather not send anything in that direction. I'd better look out for one that is already coated. They do exist.
Erik.
Xenon!
The three posted images are just wonderful looking. I rarely see examples from a Xenon. One day I may add such a lens to what I have on LTM 5cm lenses. It is most likely similar or worse than a SUmmar when it comes to flaring up in direct light. As for the Summarit, I own a "defective" one that is soft. I had the chance to buy a Sumamrit for $250 recently, but I passed since it had wipe marks.
The last image is beautiful. The DR has lots of supporters, and it is a great lens, just as rigid Summicron is.
Thanks.
I am curious why this poll was put under "Leica Screw Mount / LTM Cameras ". Actually for Leica Screw Mount / LTM Cameras, there are not too much selections as LTM rigid and summilux are very expensive.
Four lenses are LTM while two are M mount, so I picked the category fitting the majority.
There is no LTM/M category here.
