philipus
The dot on the release button helps to see if there is any film on the sprockets wile rewinding the film. I never saw a dot on a release button of a conversion before.
I've always wondered about that little dot. So it points in a different direction when there's no film in the camera, then?
I would suggest that all chrome small speed dials say 1-20. I think you only see 20 on the larger dial and then only in nickel
Perhaps they picked the smaller 1-20 dial because the bigger one doesn't exist in chrome and wouldn't match the other dials? Or maybe they were low on parts when the camera came in for upgrade, haha.
This one has just had its shutter blinds replaced, the old ones looked like they had been painted with a rubber solution.
The conversion uses the 'higher' top housing (see screw by shutter dial) and I think uses the original body since the depression milled for a circular pressure plate has been machined out to take the later type.
f16 coated Elmar seems appropriate and I am quite proud of the black hood...
Don't throw old cases away, once they have fallen apart they have another life as a half case!
Michael
Wow that's a beautiful camera! And there are only 286 numbers between it and mine, cool!
And you have that nice ring around the shutter release. Mine is missing that - can one buy them somewhere?
The hood is really nice 😀
