TJV
Anyone know if it is also supposed to resolve the new horizontal banding caused by stong light sources just off the frame?
Jorge Torralba said:I have the file if anyone wants it.
Also, I have been shooting with a 15 and the corners still show a lot of cyan.
Sailor Ted said:Ben Z,
If this solves the problem are you going to join the mostly ecstatic ranks of M8 photogs?
Ben Z said:Maybe you should check whether unofficial distribution of the firmware isn't in violation of Leica's copyright? And if the firmware or file is buggy, since Leica pulled it they're off the hook and you're on it 😱 Also I think you might be misunderstanding that 1) this version doesn't contain the cyan correction, and 2)even if it did it wouldn't work on the 15 because there is no code for it...one of the existing Leica lens codes will need to be self-coded on an adaptor and it will be sheer luck if one can be found that works just right. If a secondary tweak in Panotools is required, there isn't any point in coding it.
Sailor Ted said:Was this a message to say "we are working on the firmware so don't worry" If so that's not working.
Why did Leica release a staggered firmware update and then pull it a short while later?
Sailor Ted said:Great news Jaap- question is noise greater at 1250 ISO as some have reported? If not can you take a picture with one camera on 1.9 and the other at 1.91 and post? That will put this issue to bed if no difference or improved.
According to one or two users that had these issues it does indeed solve all known bugs. As you correctly say I did not have them (thanks be Daguerre and Saint Barnack!) so I cannot vouch for this. But at least it did not introduce any additional bugs on my camera - yet. But I am carrying a SD-card with 1.09 in my camera case to be able to downdate the camera if neccessary.Ben Z said:What I'm interested in is whether it solves the battery-charge or static electricity or whatever it is that causes M8's to shut themselves off and refuse to turn back on. And, if it solves the various banding problems not related to the original one that required the hardware repair. Since Jaap hasn't had those issues with his M8's it'll have to come from someone who had been seeing those issues. The WB problems were discovered back when Jenoptik and Leica were still on speaking terms, these other issues have surfaced more recently. What issues 1.091 does or does not address might give a clue as to when it was written😉
