infrequent
Isn't miscalibration an issue with the Zeiss Sonnars as well? Not that I own one but plenty of threads just here noting frustration with it.
Mine focuses fine at f/2.2 (ie rangefinder patch is accurate) and smaller, but front focuses by 5cm or so at larger than f/2.2. Others report optimisation at f/1.5.
Ah! Thanks for the clarification. I saw an eBay listing recently noting optimisation at f/2.8 so there clearly seems to be a way to dial in a preference or the factory setting has changed over time. Assuming the price prevents 7artisans from doing a better job with this.
For those who want to buy this lens to use on a mirrorless camera, there is another Chinese 50mm f1.1 lens (I think Kamlan it's what it's called) that costs only $150.
Got it in today. These are straight jpgs from my X-Pro2 and have not been processed. Obligatory cat photos. The first one is at f/1.1 and the second one is at f/2.8. This lens may perform gangbusters on a crop sensor.
Cropped images will look better.
Depends on what a 'better' image looks like.
In the 1.1 shot of the bamboo fence, it is obvious that the lens is very weak (at 1.1) on the outer thirds of the frame. But for a portrait where it is centered, that may look great as one may want the image to soften up like that.
With a cropped sensor, you will lose that and only have an 'ok' in sharpness image. It seems cropping will lose the personality of the lens.
It's a cute little thing and will eventually produce some great images for a bunch of folks.
From what I can see from the few samples so far, it's not a lens that would add anything new to my set.
I have lenses that are clearly this fast and weak.
It's a useful look but not one I'm lacking.
