Calzone
Gear Whore #1
- Local time
- 12:17 PM
- Joined
- Nov 11, 2008
- Messages
- 16,958
- Location
- The Gateway To The Hudson Highlands
A power steering ratio is typically 12.71:1, and my manual steering is 24:1 and pretty much nearly twice the steering input is required to provide the trade off of leverage required. On top of the higher ratio on the manual steering box my steering wheel has a 16 1/4 inch diameter rather than the 15 inch typically used with power steering.
Lock to lock is only 3 turns with power steering, and it is 6 turns with manual steering.
So why would be the hype to want manual steering? No parasitic loss of power because of no hydraulic pump. More road feel/transmission. Less hyper steering that favors high speed driving or cruising. Lastly historical or retro vibe/taste.
BTW I ran a power steering box with the 12.71 ratio without the hydraulic pump, because my manual steering box had sloppy lash from wear. Know that the modern replacement manual steering boxes are made with new tooling and are of higher more durable quality.
Pretty much power steering is wonderful for parking, or if you do a lot of city driving, but in open roads and mostly highway it is not really needed.
I kinda remember from 30 years ago the feel was more a less hyper steering was more relaxing. The only time I missed power steering was parking in tight spaces. Parking at times was a workout and required skill and experience.
So for me this takes me back about 40 years.
No power steering and no power brakes is likely an experience many drivers have not had. I also favor a manual “choke” with carbs.
I’m digging into deferring adding the Currie Ford 9-inch rear. Not required in phase one which involves keeping the inline-6 and three on the tree tranny. This saves almost $5K, and would involve keeping the retro 6 lugs and retaining drum brakes on the rear.
This might be an issue with a disc brake rotors… More research required…
Cal
Cal
