Calzone
Gear Whore #1
I needed a rest day after rubberizing my legs yesterday. It worked out for the best because of the morning rain anyways.
I did some maintenance on my bikes. On the Newesboy and Ti IBIS I removed the seatposts and applied fresh anti seize compound.
On the IBIS Avion SS I took off the rear derailleur and cleaned it up. Know that the last section of cable housing was too long to my liking and needed shortening. I also discovered I had an Avid Roller-MA-Jig, which was period correct for this bike. Basically a pulley with a sealed bearing allows a mucho short last section of cable routing with no friction to muck up the indexing. The most radical part of the bend is removed and the pulley does a great job of adding precision.
I also had a purple anodized aluminum rear derailleur bolt. They made these to replace the steel bolt and the design is to snap off to save the rest of the derailleur from getting torn apart. Back in the day one saved me from having a destroyed rear derailleur. The original steel version is my backup, so I can always go back to original. The pivot was dry so I applied a thin layer of grease. Mucho better.
Anyways these boutique upgrades are both period correct. I also found some Ti crank bolts that I had a friend at Grumman drill the hole so it would work with grease guard. How trick is that.
The 7-speed really has a solid shift With a very positive feel. The bike shifted well before but now it is supreme. Also I lubed the cables with Tri-Flow.
IBIS Avion SS weight 21 1/2 pounds with a very solid feel. It is a dream bike. I will be sending some pics to Scot Nicol. He does a Throwback Thursday on his Instagram. Pretty sure he would want to see the Ti IBIS Mountain Trials grouped out with 11-speed XTR. Last pics I sent him were when I had it rigged as a 63.59 single speed.
The steel IBIS Mountain Trials is now a 1x11 XTR.
BTW the Newsboy weighs 19 1/4 pounds.
I found a small compass the size of a nickel at REI. Kinda perfect to mount on non Ferris handlebars. All my bars are either Titanium or carbon fiber. I used some 3/32 bungie cord to secure it to my handlebars. Very trick. Kinda useful in my wanderings.
When I have some spare money, next is a cycle computer, and then a heart rate monitor. Maybe I’ll buy a unit that does both. Bike of choice will be my Newsboy.
Cal
Cal
