r4a suited for 35mm focal length?
meandihagee
10:38 AM
i want to use a 28 or a 21 with the r4. but i also would like to have an option for the 35 as an all-round lens.
as i read the brightlines of the r4 for 35 are a bit hard to work with.
also i'm guessing that the metering will be kinda difficult. since the r4 measures the entire frame in the case of a 35 the frame will be what, 50% of the whole viewfinder?
i don't really want to buy the r2, because i'll end up with a viewfinder attached on top for 28 or 21.
what to do, what to do?
I quite like a 35mm on the R4 also ... lots of space around the frame can be a bonus sometimes.
I often use the 35 on the R4M's that I have. It is comfortable enough. The 50 frame is puny and I regard it as an emergency frame only. The combination of a Biogon ZM 21f4.5 and a Nokton 35f1.4 is compact enough to work as a carry around kit.
The 28 frame is glorious in it's solitary splendor - no other frames to muck up the view.
It is still one of the "land mark" cameras for Rangefinders in my opinion.
35mm lens lines are fine and focusing seems accurate on my R4A. Its the 50mm lens lines and focus (at f/4 and below) that are difficult. For me, the camera is meant for a 28mm lens = perfection.
