I have taken my first Film with Rollei 35T. Here are some pictures
-Rollei 35T + Hoya Skylight filter 1B + BW Rubber Lens Hood
-Film: Agfaphoto APX 100, Expiration 1/2013, stored in freezer
-10 min. presoak in 500 ml distilled water 20°C
Developer- Caffenol C-L, Semistand, 1 hour
- Jobo UniTank 1520
- 72 ml Dilution of Na2CO3 = 8 grams of Na2CO3
- 5 grams of Vitamin C from DM
- 0.5 gram of Potassium Bromide
- 20 grams of Lidl Instant Coffee Bellarom Red Classic
- fill up with distilled water to 500 ml
Thoroughly mix and let stand for about 10 minutes.
Temperature - 20°C
Agitation - First minute continuous agitation (20 inversions, tap on edge to eliminate air bubbles)
- 4 inversions at 2, 4 & 8 minutes (tap on edge to eliminate air bubbles) and then let stand to finished
Stop Bath - Tip out developer, fill with water, tip out again, refill and gentle agitation for 1 minute. Tip out and repeat for another minute.
Fixer - Rapid Fixer Fomafix- 5 min.
Rinse - Ilford rinse method for B&W (but double)
Fill the film canister with water, agitate 5 times, empty.
Fill the film canister again, agitate 10 times, empty.
Fill the film canister a last time, agitate 20 times, empty.
Rinse the film in the tank 5 min. under running water.
Final Rinse - I use 2.5ml wetting agent Fotonal from Foma to 500ml of distilled water and agitate for a one minute.
http://shakyphotographer.blogspot.co.at/2017/03/my-best-caffenol-c-l-recipe-so-far.html
Thanks for your comments.
Calvary in Trnava
1/30s, f 5.6, 4.5m
Calvary in Trnava by
minotaurus 81, on Flickr
