Netsoft2k
Margus - I haven't noticed any negative impact from doing this yet but I will monitor it for a few scans and let you know if I see anything. I'll also do better before and after comparisons when I do this for the SM 5K. BTW, I did make a few test scans at 8000 DPI to see if it magically cured my banding issue but it hasn't 🙂 From what I can tell, the colors are just more balanced and there is no significant cast in the scan. I'll continue to test it and let you know but as you said, this is a very easy mod and takes less than 5 minutes. If you find an issue, it's easy to roll back to the original configuration as well.
Here is a quick comparison of a Tiff (not raw) of before and after installing the UV IR filter. I intentionally used a very underexposed slide to illustrate the difference.
Pali
Pali
