With RGB leds you could also adjust the color of the light similarly as you do in color enlargers. Eliminating the mask of colornegative.
One problem i also have, is when scanning large files in multiple parts. The light intensity can change.. as the lamp heats ups or cools down. With leds this might not be the case.
It would be probably pretty easy to put together, using arduino as controller:
https://www.youtube.com/watch?v=5uzydVKoZtM
I also think that LEDs do not produce IR or UV light, so the whole filter would be unnecessary. At least i can use my LF scan back without UV/IR filter if i use LED lightsource.
Im pretty sure somewhere out there is a ready made solution, as these things are pretty common:
http://www.ebay.com/itm/Outdoor-IP6...-LED-Floodlight-10W-20W-30W-50W-/290763685703
They have a pretty rudimentary light color controller, would only need to have more accurate controller.
