andrea gazzoni
blue channel fail
blue channel fail
Ciao Fernando, Jacek! Hi to anyone else.
As discussed with some of you I am looking for an helping hand with my Scanmate 11000. The blue channel is failing. Anything else is working ok. All I get is yellow scans.
Already done:
-any basic maintenance schedule, such as lamps, etc...
-cleaned ALL the machine: every contact has been cleaned by removing the various board and applying crc, I even removed the back panel
-inverted the optical fiber cables
-checked inside the optical module, cleaned it
-run aperture calibration routine on service program (thanks Jack), this has somehow unlocked the calibration and for some time the scanner worked fine, but then the problem is back. It seems like a bad contact somewhere..nothing that I can see under a magnifier anyway
-finally sent the PMT board to ABC Scan, they resoldered/checked here and there and sent back the part to me saying it was working fine, the PMT show good values (it was not possible for them to test it into a scanner) and pointing my attention to the spot where the Brandenburg 4479 power modules are connected to the board. Put the board back into the scanner...any change.
Now I am still here with the same issue.
I'd appreciate any suggestion on where to look before having to send the scanner to Denmark. I am almost sure this is a loose contact, just don't know exactly where to look anymore.
thank you
Andrea
blue channel fail
Already done:
thank you
Andrea
